why am i overheating
Old Jul 14, 2003 | 02:36 PM
extrmeboost's Avatar
Default why am i overheating
heres the full scenario, i replaced a head gasket and forgot to clamp a couple of coolant hoses, these hoses blew off while driving on the highway and i overheated, fixed the problem and continued to overheat, then i replaced the thermostat it seemed stuck shut, then i began to over heat with tons of white smoke and it smelled of pancakes(coolant) the car will not hold coolant the lower radiator hose was cold while the upper was hotttttt. i hope its just a bad head gasket what do you thing h-t?
Old Jul 14, 2003 | 02:37 PM
Default Re: why am i overheating (extrmeboost)
by the way this is a boosted d16y8 running an 88 crx head gasket, which worked well for a while, now im going back to the stock metal gasket
Old Jul 14, 2003 | 02:48 PM
MaxSterling's Avatar
maybe you siezed your water pump, if not then try bleeding coolent system: remember to set heater to full and run at idle till fan runs. when fan is on, it is a sign that the thermostat opened.
Old Jul 14, 2003 | 03:44 PM
i bled the system and filled it again, how do i check the water pump?
Old Jul 14, 2003 | 03:45 PM
oh and there was TONS i mean TONS of white smoke, and it looked like gasket material gathering inside the radiator and overflow bottle, the smoke actually filled the inside of the car so i figure it might be the gasket just burned up and allowed coolant to get into the combustion chamber????
Old Jul 14, 2003 | 06:04 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (extrmeboost)
Sounds like you have a blown headgasket or you have the worng one on there or you installed it wrong. Is your coolant bubbling and does it have white stuff in it?
Blaze
Old Jul 14, 2003 | 06:07 PM
Default Re: (Blaze45)
yes it bubbles, no theres no white stuff in it, but there is a tiny bit of milky white substance on the oil dipstick. this means headgasket right?
Old Jul 14, 2003 | 09:30 PM
Blaze45's Avatar
Brrraaaap!
Is there a constant stream of bubbles? and if your oil is milky, change it and possibly your HG!
Blaze
Old Jul 14, 2003 | 09:45 PM
RangerDan's Avatar
my .02 Head gasket.
Old Jul 15, 2003 | 02:11 AM
eg6beater's Avatar
Default Re: (RangerDan)
yes..if you have milky oil...it's definatley water in your combustion chamber....looks like you will need to re-do the head job...and maybe check the block or head for cracks and leaks where they meet.....my.02
Old Jul 15, 2003 | 04:34 AM
thanks guys
Old Jul 15, 2003 | 06:22 AM
Charlie Moua's Avatar
are you over heating during boosting or overheating all the time & with different amounts of load?
ok I personally think it's your headgasket........ OR very possible that you could have warped your head!
I pray that your head is fine. Re-torque your head bolts again and see if that solves it. if not change out your head gasket and at that time check to see if the head has warped at all.
HTH
Old Jul 15, 2003 | 06:23 AM
Default Re: why am i overheating (RoyFokker)
BTW how high did the temp needle go up to before you notice you were over heating?
Old Jul 15, 2003 | 07:42 AM
ohh it was in the red, and it overheated at all loads i actually had to drive a few miles in the red because it was 230 in the morning and i wasnt about to leave my car where it was and its too low to tow
BlackShingo
May 6, 2010 03:56 PM
efjones9
13
Jul 18, 2009 06:14 PM
bumpin_bass
Dec 9, 2002 11:09 PM
whagkangmakulet
Sep 23, 2002 08:32 AM
whagkangmakulet
Sep 23, 2002 06:43 AM
