HID for del sol. Which ones?
Old Jul 14, 2003 | 06:49 AM
phantom_sol's Avatar
Default HID for del sol. Which ones?
what decent kits are available for the del sol?
that both have high and low beams. or once having the hid low beam are high beams neccisary? i was thinking about getting the phillips 4100k kit. also whats the difference between the ds2 and dsr bumbs. and are casper adapters neccisary? seeing how the del sol already ahs a shield inside theheadlight
Old Jul 14, 2003 | 07:04 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: HID for del sol. Which ones? (phantom_sol)
I don't know much about del sol head lights, but I can only assume they are pretty much the same as my hatch head lights. I got a HID kit from an Acura TL with ds2 bulbs included. The difference between d2s and dsr is d2s is for halogen headlights and dsr is for projectors. The adapter will only be necessary if you get a HID kit that does not fit H4 housings. Also, I'm not sure about the "sheild" that your headlight already has, but you will blind the **** out of oncoming drivers without the adapter. You won't need both high and low if you get a GOOD HID kit. I don't every need my brights, but I'm still looking into getting some projectors because i think it would still be nice to have high beams too.
Old Jul 14, 2003 | 07:34 AM
6SPD_EK's Avatar
Default Re: HID for del sol. Which ones? (Hatchy-Ownzjo0)
wrong d2s bulbs are for projectors housings, d2r are for reflector housings....a d2r bulb is a d2s bulb with a "shielding strip (metal)" running the length of the bulb
Old Jul 14, 2003 | 07:46 AM
Default Re: HID for del sol. Which ones? (adirondackR)
so before installing the hid, would i have to get the adapter shields? in in that case can i take the current shield out of the housing?
Old Jul 14, 2003 | 08:26 AM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">wrong d2s bulbs are for projectors housings, d2r are for reflector housings....a d2r bulb is a d2s bulb with a "shielding strip (metal)" running the length of the bulb</TD></TR></TABLE>
Damn it.. I always get those 2 confused.. haha.
I'm not familiar with del sol headlights, so I don't know what "sheild" you are talking about. The adapter/sheild is super easy to install. You can install your HIDs without them and put the adapter on later if thats what you want to do.
Old Jul 14, 2003 | 08:37 AM
bearboy80's Avatar
i heard that HID light pattern sucks with stock housing unless you get one of these clear headlight covers. But they dont make one for del sol.
Old Jul 14, 2003 | 09:13 AM
ill_take_one's Avatar
Default Re: HID for del sol. Which ones? (bearboy80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that HID light pattern sucks with stock housing unless you get one of these clear headlight covers.
Exactly...
Old Jul 14, 2003 | 09:33 AM
cjblade-54's Avatar
It looks cool though...
Old Jul 14, 2003 | 05:04 PM
Default Re: (cjblade-54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjblade-54 &raquo;</TD></TR><TR><TD CLASS="quote">It looks cool though... </TD></TR></TABLE>
Ah, the typical rice-boy statement
Old Jul 14, 2003 | 05:10 PM
nwdave's Avatar
Default Re: (ill_take_one)
I know Hella has a kit that uses high/low beam settings. I think there's one other company that has that too, but I can't remember the name
Old Jul 14, 2003 | 05:17 PM
KRiS1's Avatar
Default Re: (delsolguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolguy &raquo;</TD></TR><TR><TD CLASS="quote">I know Hella has a kit that uses high/low beam settings. I think there's one other company that has that too, but I can't remember the name </TD></TR></TABLE>
Catz has one too I think
and xenondepot.com has a hi\low kit too
Old Jul 14, 2003 | 07:47 PM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that HID light pattern sucks with stock housing unless you get one of these clear headlight covers. But they dont make one for del sol.
What exactly are these? I've never seen or heard of them before..
Old Jul 15, 2003 | 12:02 PM
bearboy80's Avatar
these replace old headlight. On EG's or sol's, stock headlight covers are not clear unlike EK's. So you replace with these. here's my headlight,
Old Jul 15, 2003 | 12:09 PM
you sure those arent stock? they look like my stockies
Old Jul 15, 2003 | 12:14 PM
Default Re: (phantom_sol)
Yeah, that pict still shows lenses that are fluted...
Old Jul 15, 2003 | 12:18 PM
nwdave's Avatar
That's a stock light.
I think he posted it just for comparision purposes (between stock and the clear aftermarket ones).
Old Jul 15, 2003 | 12:22 PM
6SPD_EK's Avatar
Default Re: (POS Hatchback)
http://www.autolamps-online.com has philips hylow kit for 610.00 i think (for the 6000k ultinons bulbs) the are the only seller of philips kits thats listed (on philips corporation's website) as an authorized distributor of philips products...search for more info , BTW after MUCH research this is the Hi-low kit I have decided to purchase, pm me if you care to know why BTW it would be wise to stick with a reputable manufacturer IMO Philips, Orsam, Hella, or Catz (but don't get colored bulbs that simulate a high temp kelvin, they reduce output much more than just raising to a higher kelvin temperature bulb)
Old Jul 15, 2003 | 12:44 PM
Casey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">
What exactly are these? I've never seen or heard of them before..</TD></TR></TABLE>
i wanna know where to buy the clear eg headlights as well, thanks
Old Jul 15, 2003 | 02:19 PM
H-T Poker champion
Default Re: HID for del sol. Which ones? (Casey)
i wanna know where to buy the clear eg headlights as well, thanks</TD></TR></TABLE>
I looked them up to find out more about them.. Here is the link:
http://www.procarparts.com/sto...-HL2X
Old Jul 15, 2003 | 08:58 PM
Shreik's Avatar
i've been lookin for lights like that for a while now.
has anyone seen a shop/e-store that sells the TYC clear headlights?
does anyone actually have them? i'd like to see how they compare to these.
http://www.elegantebytyc.com/civic.html
Acura Del Sol
Lighting
Feb 23, 2012 07:36 AM
Rangedrecon
30
Dec 12, 2009 11:43 AM
MRsol
Lighting
Jun 24, 2009 01:22 AM
STooK02780
Sep 28, 2004 05:41 PM
