where to buy 12v 3 way solenoid for diy boost controller?
Old Jul 13, 2003 | 06:59 PM
buckfittyone's Avatar
Default where to buy 12v 3 way solenoid for diy boost controller?
somebody posted a site where you can get cheap 3 way solenoid valves for home made electric boost controllers,i searched but i couldn come up with anything,if you know what site im talkin about please post the link
Old Jul 13, 2003 | 07:31 PM
bump
Old Jul 13, 2003 | 08:36 PM
Old Jul 13, 2003 | 09:51 PM
twkdCD595's Avatar
Default Re: (buckfittyone)
I think it was a grainger or something like that they said...
Old Jul 13, 2003 | 10:53 PM
mos's Avatar
mos
Default Re: (twkdCD595)
Try mcmaster.com, they have cheap solenoids.
Old Jul 14, 2003 | 06:20 AM
yeah i know about the grainger valve ,i alrteady have 2 of those now i need 2 12v 3barb solenoid valves and i can make a 2 stage electric boost controller,ive seen the ones on mcmaster.com but none of those use 12v,and there alot more expensive then the ones i saw on that site
Old Jul 14, 2003 | 08:29 AM
mos's Avatar
mos
Hrrm, i got some 12v solenoids from mcmaster for less than $20 each. They are for liquid, but I think they'll do air also.
Ed: they are on page 385 in my catalog. It says they are compatible with gases as well as liquids, but I don't know how much heat they can tolerate.
Old Jul 14, 2003 | 02:12 PM
rioninja's Avatar
Default Re: where to buy 12v 3 way solenoid for diy boost controller? (buckfittyone)
I plan on making a dual stage controller, except im only going to use a single boost controller, and a 2 way solenoid. When the solenoid is open it will just use the stock wastegate setting, and when closed will route through my boost controller.
Every think about just doing it this way? much easier, providing your ok with the stock wastegate setting.
If you still have trouble finding a valve, the SAAB APC system uses a 3-way valve. Do an ebay search for "APC solenoid" or similar.
Old Jul 14, 2003 | 04:33 PM
Default Re: where to buy 12v 3 way solenoid for diy boost controller? (rioninja)
yeah i thought about using one solenoid and one boost controller but i want to have both adjustable high and low boost,i think your going to need a 3 way solenoid valve to make the boost controoller you want, cuz one hole goes to intake manifold ,one goes to the boost controller then to the wastegate, and the last one is vented into the atmosphere,i dont see how you can do it with just a 2 way valve.but of course i could be wrong.thanksx for the info
Old Jul 14, 2003 | 05:00 PM
just searched on ebay but i couldnt find exactly what i need,so if anyone comes across 2,12v 3 way solenoid valves,please sell them to me,ill pay good$$$$ i only need them if they can flow in both directions.
Old Jul 14, 2003 | 05:21 PM
Burke's Avatar
Banned
that one on mcmastercarr.com looks like it would work great and for only 18 bucks, i think i am gonna try one myself
Old Jul 14, 2003 | 10:07 PM
ok ,for my boost controllers im using 1/4 npt fittings and the solenoids on mcmastercarr are 1/8 nptwill that affect the boost controller....?im sure it will affect the signal going to the wastegate
Old Jul 15, 2003 | 06:16 AM
MassScene
Feb 26, 2007 08:03 PM
wezzel19
Aug 7, 2006 08:19 PM
Boltz
Mar 26, 2005 09:49 AM
hbkxtbone
Sep 1, 2004 07:35 PM
Pat
Mar 2, 2003 09:32 AM
