Turbo Gurus, please help, I am getting dual boost readings!!!!
I have an Omori 1.0 bar gauge and an SAFC. The omori will read about .10 bar higher than the SAFC at all times. I'm not sure which one to trust, the omori is the only thing tapped into vaccum source.
What should I trust?? Has this happened before?
if you run your boost gauge to the intake manifold, I'd go with that.
Or go with whatever is higher....it's better to overestimate than under estimate
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">if you run your boost gauge to the intake manifold, I'd go with that.
stan
thats exactly what im doing. Goddamn that safc. Also, would boost creep be lessened if i opened the exhaust up from a 2.25" tanabe racing medallion (no cat) to say, a 2.5-2.75" setup?
stan
Accord94DX
Jun 15, 2003 01:54 PM
