breaking in and maintaining motor
Old Jul 13, 2003 | 07:03 AM
jeremy.'s Avatar
Default breaking in and maintaining motor
i have a rebuilt 99 gsr block and 2000 head...there is no miles in it so i have to break it in. besides changing the oil every 3000 miles what other things to you guys do for maintance
any tips to breaking in my motor correctly?
Old Jul 13, 2003 | 07:58 AM
sspikey's Avatar
Default Re: breaking in and maintaining motor (ek_jeremy)
ALWAYS Important to remember PRIME YOUR ENGINE!!!! crank it by hand a few times with your valve cover off till you see oil start coming out and pressure building up. if not imagine your engine at start up with no oil pressure.
After that
2 ways people have mentionned.
1 is drive the motor easy and change your first oil like 500 miles after along with your filter. debris will come out by the tons in the first foot steps of a motor's start.
2nd is the first as the same but instead for the first like 50 miles drive easy then after that SLAM IT DOWN HARD! reason being you need pressure to seat the rings and such.
i personally havent tried the second (dont have ***** )
Old Jul 13, 2003 | 10:25 AM
4crx4me's Avatar
As I recall, To break in an engine safely, keep rev's below something
like 3500 and ALWAYS vary your speed and rpm's.
Don't stay at one certain MPH or RPM too long.
And transition rpm's gradually NEVER quickly.
The rings and bearings need to see high and low rpm's to seat properly.
And what was posted above about initial oil changes.
HTH
bandit67
17
Nov 10, 2009 05:31 PM
SupraRXZ
10
Jun 13, 2007 02:32 PM
turbochargeb18c
Jul 7, 2005 07:01 AM
crxtreme27
May 1, 2003 12:35 PM
shawnc21
Dec 3, 2002 08:02 PM
