leaking coolant/problem with gauge cluster
Old Jul 12, 2003 | 03:38 PM
Tammy_EP3's Avatar
Default leaking coolant/problem with gauge cluster
my car is leaking coolant IN the car...both passanger side and driver sidefoot area...passanger side is the worse...its not constant leakage...but its alwais moist there...and after i drive my car thats when coolan tleaks the most. is this a broken/not hooked up heater core?? someone told me its the problem with the heater core i just want to make sure.
Also another problem i enountered was that after putting in my stock motor, my gauge cluster doesn't work. gauge cluster lights, hazard light, battery light, srs light work....actual gauges, turn signals, other warning lights do not work....its not the prolem with the wirings behind the dash--but i do know that when we were plugging the wiring harness in, there was one plug that wans't pluged ito anything--maybe this could of been the problem? im not sure, please help
Thanks!
-Tammy-
Old Jul 12, 2003 | 04:33 PM
J2turbo21's Avatar
Default Re: leaking coolant/problem with gauge cluster (SweetieGirl)
First one sounds like its your heater core,i beleive its the only coolant thing that goes into the drivers area.Also which gauge is the one thats not working?
Old Jul 12, 2003 | 06:08 PM
Ryan C's Avatar
Default Re: leaking coolant/problem with gauge cluster (J2turbo21)
heater core fo sheezy
Old Jul 12, 2003 | 06:22 PM
PHiZ's Avatar
You're leaking coolant out your gauges!?
j/k good luck.
-PHiZ
Old Jul 12, 2003 | 06:55 PM
Tammy_EP3's Avatar
all the gauges don't work...fuel, speedometer, odometer, temp
Old Jul 12, 2003 | 07:13 PM
BROOD's Avatar
Heater core failure, either the core has a hole in it or the connection are cracked. It will need to be removed for inspection and replaced if nessesary.
If none of your gauges work and the cluster is not supplied with power, recheck the cluster connections. If you have to get a DMM on the terminals and start tracing the power supply back to the fuse box.
cthan3o3
Jul 26, 2005 09:48 PM
sirpsychosexy1
Jul 8, 2005 11:28 AM
bm3w
Aug 6, 2004 08:41 AM
rexnation
Jul 14, 2004 03:08 PM
