HELP! Instrument Gauge Cluster Not Working Fuel Water Temperature Temp Speedometer Tach Tachometer S
Old 11-09-2003, 12:05 PM
cpforyou's Avatar
Default HELP! Instrument Gauge Cluster Not Working Fuel Water Temperature Temp Speedometer Tach Tachometer S
Hello Everyone,
I did a search already and have come up w/ Hazard Fuze, Fuzes, etc. etc.
This is what works:
Battery Light
Signal Lights (When Hazard Light button is pushed)
SRS Light (Since my airbag is disabled)
Dimmer Lights (When Headlights Are On)
This is what doesn't work:
RPM Gauge (Tachometer)
Speedometer
Fuel Gauge
Water Temperature Gauge
Oil Light (When starting the car it usually comes on)
Signal Light (When trying to signal left and right)
I checked the fuzes under the hood and under the drivers side, and none of them are blown. I replaced my gauge cluster, and it's the same problem so it's not the gauge cluster.
I have a 1992-1995 Honda Civic EX Coupe.
Any other suggesstions?
Old 11-09-2003, 05:14 PM
2.7(p/t)
sander's Avatar
Default Re: HELP! Instrument Gauge Cluster Not Working Fuel Water Temperature Temp Speedometer Tach Tachomet
If you have the haynes service manual, i would dig in to your ecu wiring and start checking voltages for each wire, sometimes a blown resistor can lead to those problems and a blown resistor can be caused by something as simple as some water getting in to your ecu, from your AC evapartor or a leak even...
just a thought...
-sander
Old 11-10-2003, 06:52 AM
EE_Chris's Avatar
Can't really comment on 92-95's, but on 6th gens, the odometer, speedometer, tachometer, engine temp and fuel gauge all share a common power feed. In the under-dash fuse box, its a 7.5A "Meter" fuse.
Old 11-10-2003, 07:43 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Can't really comment on 92-95's, but on 6th gens, the odometer, speedometer, tachometer, engine temp and fuel gauge all share a common power feed. In the under-dash fuse box, its a 7.5A "Meter" fuse.</TD></TR></TABLE>
There was a 7.5A fused I checked in my 5th Generation Civic that looked good, but I'll double check that again. It's nice to know it comes from a POWER FEED. If I knew which wire it is, I could bypass it directly to the battery to find out if that's the problem.
Old 11-19-2003, 03:59 PM
nickwilmot's Avatar
Did you ever find what caused your problem. Because I'm having the same one!
Old 11-30-2003, 08:30 PM
LegoZ81's Avatar
Check your grounds I can't say which one from sure but my friend had the same problem. He also had a power feed pop off the back of the fuse block on the back talk about a PITA to diagnose.
Old 05-16-2004, 05:31 PM
RC_SKUBY's Avatar
Im having the exact same problem right now i checked both every fuse in both the under the dash and hood panels and everyone of them are ok. what specific fuse controls these guages? or any other advice would be great, thanks.
Old 05-16-2004, 07:00 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skuby_do &raquo;</TD></TR><TR><TD CLASS="quote">Im having the exact same problem right now i checked both every fuse in both the under the dash and hood panels and everyone of them are ok. what specific fuse controls these guages? or any other advice would be great, thanks.</TD></TR></TABLE>
My culprit was the fuse box. There was a short inside. If your problem is exaclty like mine, you can either replace the fuse box, or just bypass that fuse and run a new line from the accessory with your own fuse.
Old 05-16-2004, 08:22 PM
RC_SKUBY's Avatar
thanks man ill check that out, hope it works.
xsicrx120
09-23-2009 02:00 PM
MBlake55
05-25-2006 06:24 PM
rexnation
07-14-2004 03:08 PM
cpforyou
11-10-2003 07:44 AM
Tammy_EP3
07-12-2003 07:13 PM
Quick Reply: HELP! Instrument Gauge Cluster Not Working Fuel Water Temperature Temp Speedometer Tach Tachometer S
