HELP - I have a partially Stripped Tensioner Bolt...
Old Jul 12, 2003 | 01:30 PM
Ruby Civic's Avatar
Default HELP - I have a partially Stripped Tensioner Bolt...
OK, I have a nearly finished hybrid b18c BUT have a partially stripped 14 mm tensioner bolt - any suggestions on how I can cinch up the timing belt.
Do those stupid looking alligator things/sockets work, or where can I get something that will tighten that mug up?
Tight as hell on the driver side of the engine bay with this motor in an EF (91 civic)...
Helpful suggestions if you can...
Old Jul 12, 2003 | 04:57 PM
J2turbo21's Avatar
Default Re: HELP - I have a partially Stripped Tensioner Bolt... (Ruby Civic)
To be honest with you i would get a new bolt.What happens when you tighten it more and it strips more,its gonna be a PITA to get it out.Swing buy honda and get one for a few bux.If it was stripped a little you should still be able to use a normal socket but if you cant its time for a new one
Old Jul 12, 2003 | 11:04 PM
smokey2.0's Avatar
Default Re: HELP - I have a partially Stripped Tensioner Bolt... (J2turbo21)
you should buy a new bolt, but you can always use a 6 point socket to get it out. on that particular bolt, is not good to use a 12 point socket because your chances of stripping the head of the bolt will increse. if the head of that bolt is stripped, use a 8 point socket. have a friend place a pry bar behind the rachet your using, to keep the socket square to the bolt and also to keep you from further stripping the head of the bolt. that's what i did when i stripped mine, and up to this day i still have the same stripped bolt in there but i used the method i descrived every time i have to touch that bolt. hope that helps
Old Jul 13, 2003 | 06:26 AM
Ruby Civic's Avatar
Default Re: HELP - I have a partially Stripped Tensioner Bolt... (smokey2.0)
yea, think i am going to get a new bolt...i used one of those home depot husky sockets that has the rounded corners inside the socket - damn...sh-- ready to go otherwise
Old Jul 13, 2003 | 08:27 AM
Sinner's Avatar
dam I stipped out the block using a air tool on that bolt and I just got another motor... then again D motors are cheap :-).
Nick
Old Jul 13, 2003 | 09:19 AM
Ruby Civic's Avatar
Default Re: (Sinner)
yea, i wish - b18c jdm in mine
Old Jul 17, 2003 | 04:05 AM
Ruby Civic's Avatar
Default Re: (Ruby Civic)
well, i loosened the bolt with the sears kit which did not major damage it, and then tightened up the exhaust side of the belt, then reninserted the bolt and it was as easy as you can get.....i think i had not pre-tightened the ex side well enough - so simple solution
Old Jul 17, 2003 | 09:04 AM
chictunner97ex's Avatar
do yourself a favor though and get a new bolt, they only cost .52 cents at the dealer, and trust me it will save you the hassel later! i went through haveing to use a reverse easy out on mine cause it was stripped so bad. gloria
psychotech
Oct 15, 2010 11:56 AM
BROKE.eg
17
Nov 25, 2005 08:19 PM
seeeya04
Nov 24, 2005 03:25 PM
XDEep
Sep 18, 2004 09:37 PM
Ash J. Williams
May 12, 2004 07:46 PM
