A/C PROBLEM
Old Jul 11, 2003 | 10:33 AM
klymax2nd's Avatar
Default A/C PROBLEM
I AM HAVING TROUBLE W/ A/C THE COMPRESSOR IS NOT COMING ON, IT'S A 90 HONDA ACCRD DX, IT JUST STOP WORKING THE OTHER DAY, I CHECKED THE FUSES BY THE FOOTREST AND ITS FINE. BUT NOTHING WHEN I TURN A/C SWITCH ON.
ANY SUGGESTIONS WILL BE APPRECIATED.
Old Jul 11, 2003 | 09:18 PM
RUBZERK's Avatar
Default Re: A/C PROBLEM (klymax2nd)
just take it to a shop. thats the best advice you should take
Old Jul 12, 2003 | 12:00 AM
Stripped Honda's Avatar
99-0104
Default Re: A/C PROBLEM (RUBZERK)
probally low on freon take it in and have it serviced
Old Jul 12, 2003 | 05:35 AM
YeuEmMaiMai's Avatar
there have gotta be like uhh 50 million threads on AC problems... search is your friend....
If your compressor is not comming on, it is likely due to the fact that you have no freon in your system or you have a bad pressure switch or you don't have +12 going to the clutch or your ECU is not turning on the A/C
Old Jul 14, 2003 | 10:15 PM
honda_boy's Avatar
i can almost garentee it is a wiring problem!!!! unless you know anything about wiring take it in and have a tech look at it!
Old Jul 14, 2003 | 11:28 PM
FREAKquency04's Avatar
get your R134a checked thas the fluid that refrigerates the freon
imadigitalgod
12
Jun 23, 2011 05:10 PM
Adankid
Jun 16, 2009 03:12 PM
gaberhodes
Jun 18, 2005 02:52 PM
toads
Nov 15, 2004 06:29 AM
