fuel rail question H22a1 what side do I splice the fmu on?
Old Jul 10, 2003 | 07:49 PM
nigel's Avatar
Default fuel rail question H22a1 what side do I splice the fmu on?
on an H22a1 what side do I splice the fmu on to the fuel rail??? I dont want to hook that thing up wrong.
Old Jul 10, 2003 | 08:38 PM
Flamenco-T's Avatar
Default Re: fuel rail question H22a1 what side do I splice the fmu on? (nigel)
On the FMU, there are 3 ports.
Top port is vacuum sources [hook this up to any vacuum source]
Side port is inlet port [ hook this port to the ORIGINAL return port from the stock FPR]
Bottom port is return port [ put the stock hose that you took out from the stock FPR to this port ]
you're basically bypassing the fuel retunr from the stock FPR to the FMU first, then back to the fuel return
HTH
stan
Old Jul 10, 2003 | 09:19 PM
nigel's Avatar
naw what I mean...... the fuel rail, which fuel line to I cut to splice in the fmu and fuel pump?
theres fuel line on the throttlebody side and theres the fuel pressure regulator side. which one do I go to.
thanks
Old Jul 10, 2003 | 09:22 PM
Flamenco-T's Avatar
Default Re: (nigel)
fuel pump goes in between fuel filter and fuel rail, FMU goes between FPR and the tank
stan
Old Jul 11, 2003 | 03:27 PM
nigel's Avatar
Default Re: (Flamenco-T)
ok I have everything on the right side now, but when I take it into boost at basically hits revlimiter, and leans out thats at 0psi, I am thinking I may have the fmu backwards. ok the fuel neck goes into the in on the fmu, and the out goes to the tank. is that right?
Old Jul 11, 2003 | 05:18 PM
Flamenco-T's Avatar
Default Re: (nigel)
do you have pics on how you install it ? post it, I can check it for you
stan
Old Jul 11, 2003 | 08:57 PM
nigel's Avatar
OK I got it figuerd out, we need a missing link the check valves arent cutting it. thanks for all your help man!
ityab0y
Nov 6, 2005 09:21 AM
redsled00
Jun 23, 2005 06:38 AM
JDM96SpecCTR
Nov 11, 2004 07:20 PM
spoon23_JDizM AkA SpOoN20
Apr 29, 2004 11:02 AM
90whiteGS
Jun 12, 2002 05:40 PM
