cars leaking fuel like MADD?any reason's why?
ok i put the fmu on and ran the out valve to the return line-the other to vacuum and the one that goes to the reg is leaking fuel like a ************,at first i thought it was missing the o ring but notices its on....i have no clue , i have a tight *** fuel line connected to it with a clamp.....anyone have this happen to them?
Re: cars leaking fuel like MADD?any reason's why? (spoon20)
Is the FMU leaking from the bottom? When I had my FMU it started leaking after awhile. I just put some JB weld around it and that fixed the leak.
Re: cars leaking fuel like MADD?any reason's why? (sneakypete)
not from the fmu at all,its leaking from bottom of the fuel line,buts its on there tighter than ****...with a clamp,my clue is that i think to much fuel pressure might be causing this?
Nice avatar! You using proper fuel line or is it braided or some other rubbish?
yeah only thing is just check all your lines, usually fuel pressure shouldn't be that high if ur at idle. oh yeah don't forget to not smoke while working on those lines.
Hahaha, your avitar looks like Michael Jackson with ****.
Scary as hell.
Now onto your problem, have you check the line going to the tank?? is there fuel returning to it???
It could be a stuck FMU, seen many happen. It could be stuck so bad that it's not letting fuel return back to the tank.
Scary as hell.
If it's the FMU then you will have get another one.
I've never taken mine completely apart but only changed the discs.
most of those autozone fuel lines are only able to hold no more then 50 psi.. u probly need a high pressure hose because FMU's bring the pressure up real high
Re: cars leaking fuel like MADD?any reason's why? (J337_UNIT)
ok i tied the line from my return line to the out valve of the fmu,now on top is the other valve i got going to my reg...forcing fuel into the reg....and the back valve on the backside of the fmu as being into my intake manifold for vacum source....is that ryte,is there supposed to be fuel dumping backing into my regulator?????
nigel
07-11-2003 08:57 PM
