how do you clean your fmic?
Old Jul 10, 2003 | 04:10 PM
B_1_8_hatch's Avatar
Default how do you clean your fmic?
how do you clean your front mount intercooler to make it all nice and shiny?
Old Jul 10, 2003 | 04:40 PM
mos's Avatar
mos
Default Re: how do you clean your fmic? (93hb)
Clean? Brake cleaner, oven cleaner, engine degreaser... probablys a good idea to do the insides also.
Shiney? polish that sucker. Or if its already polished, restore the shine with some mothers aluminum polish.
Old Jul 10, 2003 | 05:40 PM
so just spray the intercooler all over with engine degreaser and then hose it off?
it won't mess up the intercooler.
i got something to shine it up already..thanks
Old Jul 10, 2003 | 08:19 PM
any other tips out there?
Old Jul 10, 2003 | 08:33 PM
Flamenco-T's Avatar
believe it or not, I used paint remover....and paint thinner
stan
Old Jul 10, 2003 | 08:45 PM
Finest's Avatar
Default Re: how do you clean your fmic? (Flamenco-T)
To clean the outside, any degreaser should work. If all fails, Simple Green works on everything!
But for the inside, try rinsing it with gasoline. You'll be surprised at how much oil buildup gets in there. Rinse it out thoroughly, drain it, and let it dry overnight.
Old Jul 10, 2003 | 09:05 PM
mos's Avatar
mos
Default Re: how do you clean your fmic? (98CTRCoupe)
I would just use oven cleaner just because its cheap and easy to find. Or you could use some of that octane boosting toluene or xylene to clean it. That'd work real well also if you've got a bit extra laying around.
Old Jul 10, 2003 | 10:21 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Hmm... I was wondering the same thing. So far, I've been just using really hot water, and a gentle soft brush to brush away the dead bugs.
Seems to be working so far, but I'll try that degreaser stuff too!.
Old Jul 10, 2003 | 10:27 PM
Drew Peacock's Avatar
Default Re: how do you clean your fmic? (Snafu-Si)
Garden hose on the inside of the engine bay it pushes all the bugs n **** off. Brasso for polishing. Yeah I cleaned the inside with petrol works well.
Old Jul 11, 2003 | 03:02 AM
egg's Avatar
egg
Default Re: how do you clean your fmic? (turbozxi)
run a wire brush right over the fins back and forth, im sure that would get rid of the dirt and grime
TURBODC4TEG
Jan 12, 2005 03:16 PM
EARLdaSQUIRREL
Jul 21, 2004 08:51 PM
yangtech
Jun 20, 2004 01:28 PM
turbocivic2k1
Mar 26, 2003 12:31 AM
EVOCELICA
Nov 11, 2002 08:04 AM
