clunk in lf wheel
Old Jul 10, 2003 | 08:31 AM
Lo-Buck EF's Avatar
Default clunk in lf wheel
at the last autocross, i found i had a bit of a clunk and some play in my lf wheel. it looked to be a bad upper balljoint. when i removed the uca, the balljoint was definately worn. so i replaced the whole uca (cause its easier) but i still have some play. the wheelberring is new, so im pritty sure its not that. the tierod is new and the play isnt the tierod type. i did tighten everything, but i will double check. the only thing i can think of is a worn cv joint. any ideas?
-spenc
Old Jul 10, 2003 | 12:24 PM
4door_gsr_ftw's Avatar
Default Re: clunk in lf wheel (Lo-Buck EF)
Hows your axle?
Old Jul 10, 2003 | 12:30 PM
Lo-Buck EF's Avatar
Default Re: clunk in lf wheel (Pacman88)
well, i got home and took a look with the wheel off. apparently, the uca bolts were loose. thats my fault for not checking them . so i torqued them to spec and put everything back together and everythings lookin (and feelin) good. ill keep an eye on them to see what they do. maybe they require loc-tite?
Old Jul 10, 2003 | 01:24 PM
Loc-tite will help them from coming loose again. Use some loc-tite on the uca bolts then retorque them, that way they will stay together. Retorqure them after you have driven on them for awhile.
Old Jul 11, 2003 | 08:44 AM
Lo-Buck EF's Avatar
yea, im gonna check them sunday evening when i have some time (remove and retouque) but ill keem an eye on them while autocrossing this weeken. has anyone ever had trouble with this or is it just because the bolt werent torqued when i received the part
Xvisor
Honda Ruckus and Scooters
Jun 27, 2018 08:23 AM
Rick James
10
Sep 25, 2008 05:07 PM
slowB20ej8
Jan 18, 2008 11:17 AM
ITRDC2R
Jun 1, 2007 05:43 AM
cmyrex
Nov 14, 2006 08:28 AM
