Wheel shaking..
Wheel shaking..
I was changing my breaks the other day and when i went to put the wheel back on i noticed that the wheel was able to move from left to right like if when you havent put on the lug nuts yet... any idea of what it may be??
Re: Wheel shaking.. (Rick James)
it happened to my EG and it turned out the outer tie rod end bushing shot..so check your tie rod..ball joint (if there is any leaking) and tight your axle that connects to wheel hub
Re: Wheel shaking.. (Thateguhate)
if you have the wheel on and torqued down and you move the wheel left to right and its loose, then its a tie rod. move it top to bottom and its loose then its wheel bearing
1 Post
Re: Wheel shaking.. (iluvmyhnda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmyhnda »</TD></TR><TR><TD CLASS="quote">if you have the wheel on and torqued down and you move the wheel left to right and its loose, then its a tie rod. move it top to bottom and its loose then its wheel bearing</TD></TR></TABLE>
Thanks for clarifying!
Re: Wheel shaking.. (dj_gizmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_gizmo »</TD></TR><TR><TD CLASS="quote">so what is the easiest way to fix a tie-rod if that is the problem because i think i may have the same issue</TD></TR></TABLE>
check this thread out..
https://honda-tech.com/zerothread?id=2333340
Location: Filthadelphia City of Brothers and Love, PA, USA
Not correct. If the wheel moves up and down its a ball joint. A bad wheel bearing will howl when you drive, and you can pull the wheel in and out a little if its really gone, but you'll definately hear it at that point.
Re: Wheel shaking.. (Hondaman56)
ill post a video cause i could move it all ways around but its weird cause the axel, wheel and rotor move but not the caliper...
Mr. Vapor
12-05-2002 05:29 PM
