Rear hatch lock...
Old Jul 10, 2003 | 04:26 AM
davidnyc's Avatar
Default Rear hatch lock...
I am stripping the car for ECHC. The rear hatch lock is electrically controlled with that little switch. If I unplug everything and pull out the switch motor, can I still unlock and lock the hatch with the key? I believe I can, I just want to make sure, I don't want to start pulling everything off and then the hatch cannot be secured.
Old Jul 10, 2003 | 04:45 AM
Willard's Avatar
Default Re: Rear hatch lock... (davidnyc)
H2 = owned in '04
Why not pull all of the latch stuff out and use some of those JDM spring tie downz?
Hatch shocks/latch = gone.
Old Jul 10, 2003 | 05:22 AM
davidnyc's Avatar
Default Re: Rear hatch lock... (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">H2 = owned in '04
Hatch shocks/latch = gone. </TD></TR></TABLE>
Elaborate.... I am not "up" on my JDM stuff
I was thinking of maybe trying to use "hood latches" or some sort of clips on the back edge. But, I'd rather minimize the drilling that I have to do.
PS=&gt; I hope I do well in H2 next year. I was three seconds back to the H2 times at Summit Point on my time trial time, using stock suspension. I hope a stiffer suspension and more experience can get me two to three seconds.
Old Jul 10, 2003 | 10:31 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of maybe trying to use "hood latches" or some sort of clips on the back edge. But, I'd rather minimize the drilling that I have to do.</TD></TR></TABLE>hrmm.... drilling = required for those bad boyez.
wonder if a older teg ('95) latch would work better vs. the electric one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">PS=&gt; I hope I do well in H2 next year.</TD></TR></TABLE>
you will...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">I was three seconds back to the H2 times at Summit Point on my time trial time, using stock suspension.</TD></TR></TABLE>
exactly..
removing the stock header/cat would help a 'little'
Old Jul 10, 2003 | 10:35 AM
Dirt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">wonder if a older teg ('95) latch would work better vs. the electric one.</TD></TR></TABLE>
It does. '97
Old Jul 10, 2003 | 10:57 AM
MissMyHonda's Avatar
Default Re: Rear hatch lock... (BrewCityR)
Hrmm what is involved here, I hate the electronic latch, 1/2 the time it doesn't reset and i'm sitting there opening and closing my hatch
Old Jul 10, 2003 | 11:28 AM
thk's Avatar
thk
Members Only
dave,
when i unplugged the battery, the hatch wouldn't open (for the airbag tray). figured out that if you turn the key all the way and hold it there while moving the latch will open the hatch.
Old Jul 10, 2003 | 11:47 AM
TypeR 01 886's Avatar
Default Re: Rear hatch lock... (thk)
im guessing you dont have a warrantee and if you dont I would just lubricate the module.
Old Jul 10, 2003 | 12:24 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">I am stripping the car for ECHC. The rear hatch lock is electrically controlled with that little switch. If I unplug everything and pull out the switch motor, can I still unlock and lock the hatch with the key? I believe I can, I just want to make sure, I don't want to start pulling everything off and then the hatch cannot be secured.</TD></TR></TABLE>
if you disable the power mechanism the lock will not work.
Old Jul 10, 2003 | 12:46 PM
magic hat #9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR &raquo;</TD></TR><TR><TD CLASS="quote">
It does. '97 </TD></TR></TABLE>
hmm, my electric latch sticks open often enough i'd replace with a mechanical version, however, i'd guess my key wouldn't work.....
can the tumbler be removed from my electric latch and be attached to a mechanical one? without costing more than $10?
Old Jul 10, 2003 | 02:17 PM
Hooch'n's Avatar
Default Re: Rear hatch lock... (magic hat #9)
zip-tye
Old Jul 11, 2003 | 05:01 AM
Willard's Avatar
Default Re: Rear hatch lock... (Hooch at 8400-RPM)
http://www.kingmotorsports.com...tegra
$75...
Old Jul 11, 2003 | 05:12 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">http://www.kingmotorsports.com...tegra
$75... </TD></TR></TABLE>
I'm guessing since it's Mugen it's $75. per fastener?
There we go again spending Daves money...
BTW while he's at it, can he replace the rear quarter windows and hatch glass with FAL pieces in his preferred racing class? (yet more ways to spend Daves money)
Old Jul 11, 2003 | 05:23 AM
Willard's Avatar
Default Re: Rear hatch lock... (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">can he replace the rear quarter windows and hatch glass with FAL pieces in his preferred racing class?</TD></TR></TABLE>I don't think that is allowed in Honda Challenge.
He won't need it anyway... he will r0ll the field with only a few more mods.
Old Jul 11, 2003 | 09:02 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that is allowed in Honda Challenge.
He won't need it anyway... he will r0ll the field with only a few more mods. </TD></TR></TABLE>
Yah, cause we need more yellow integras like we need more red hatchkrappers
Lithel
Apr 7, 2009 08:48 AM
B18CR-X
Apr 2, 2004 01:57 PM
xJ.SLOTHx
Jan 13, 2004 07:11 PM
spd18
Mar 7, 2003 04:19 PM
