Where do you guys usually buy your BRASS BARB FITTINGS, locally?
Old Jul 9, 2003 | 01:45 PM
krazy's Avatar
Default Where do you guys usually buy your BRASS BARB FITTINGS, locally?
im having trouble locating a place that sells brass/stainless barb fittings. ordering online is cheap, but usually they have a minimum to order, and shipping is added on top. would lowes or OSH have things like this? or home depot? thanks.
krazy
Old Jul 9, 2003 | 01:51 PM
GreddySi99's Avatar
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (krazy)
home depot or lowes
Old Jul 9, 2003 | 01:53 PM
b18bturbo's Avatar
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (intercooledJRSC)
as long as you just need npt fittings home depot carries a wide selection of barb npt style most npt fittings 1/8npt
Old Jul 9, 2003 | 02:12 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (b18bturbo)
Locally? Flamenco-t.
Old Jul 9, 2003 | 02:30 PM
krazy's Avatar
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (Arturbo)
cool, ill go check home depot out.
thanks guys.
krazy
Old Jul 9, 2003 | 04:47 PM
scttydb411's Avatar
ace, lowes, homedepot, pepboys.
Old Jul 9, 2003 | 10:33 PM
SiR Kid's Avatar
New User
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (scttydb411)
We've got this badass pneumatic fitting specialty place called Fluid-Aire here. $3.52 with tax for the fitting to make the GE oil supply work directly with a -3AN line.
They also carry bulkhead fittings, valves, stainless lines with brake line ends they can install for a small fee.
This place rocks, but they really don't LIKE dealing with smaller walk in people. They like big contractor job parts lists.
Old Jul 9, 2003 | 11:41 PM
lazerus's Avatar
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (SiR Kid)
arturbo, that's not local, that's across the room!
Old Jul 9, 2003 | 11:47 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Where do you guys usually buy your BRASS BARB FITTINGS, locally? (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">arturbo, that's not local, that's across the room!</TD></TR></TABLE>
LOL, its still local.
dE.fUsEd
Nov 9, 2011 08:13 PM
1sikhatch
Dec 28, 2009 10:11 AM
Trooper
Sep 25, 2003 09:45 AM
rOby
Nov 14, 2002 08:42 PM
D-SPEED
Dec 12, 2001 09:59 PM
