any T3 b18b's out there?
Old Jul 9, 2003 | 12:28 PM
HuskerHybrid's Avatar
Default any T3 b18b's out there?
any of you guys running a T3 turbo on your LS? i'm trying to decide if it is the right one. i'm looking at around 250hp. what times are you getting, hp numbers? also, i tried to search but since "T3" is two letters it doesn't work.
Old Jul 9, 2003 | 12:41 PM
Bspec18's Avatar
i have a t3, great spool up time. unfotunatley no time slips or Hp numbers to give. Still working on fuel management.
My impressions, it might not pull as hard as a t3/t4 but on fwy driving at 3200 rpms at 9psi. its already hauling *** and there's still 3600 rpms till redline. really great for street driving too
Old Jul 9, 2003 | 05:03 PM
g2ls_turbo's Avatar
i also have a t3 turbo in my teg, its actually a b18a engine but pretty much the same, if you want higher hp like 250 and up, i would recomend a t3/t4 turbo. try searching t3 turbos, instead of jut typing in t3
Old Jul 9, 2003 | 05:09 PM
AlLMoToRvOtEr's Avatar
Default Re: any T3 b18b's out there? (HuskerHybrid)
Go with a T3/T4E, my buddy has that turbo and with a B20 stock motor his hatch went 12.9. That was with 24 inch slicks and just a FMU.
Old Jul 9, 2003 | 06:12 PM
are you guys saying a T3 is too small? aren't T3/T4 turbos good for like 500+ hp? i only need half that, i'm not looking to do any bottom-end work, just a quick spooling and potent turbo. is there something between a T3 and T3/T4 that would be a good compromise?
Old Jul 9, 2003 | 11:24 PM
I'm sure with the right trim it might be. But the T3/T4E turbo is a good all around turbo it doesn't spool up to quick but yet it still spools plenty fast at the track. It is fully spooled by like 3500 RPM's.
Old Jul 9, 2003 | 11:49 PM
lazerus's Avatar
Default Re: any T3 b18b's out there? (turboDC2)
if you're looking for 250 whp, i'd go with a T-3 60 trim with a .48 a/r turbine housing.. or something similar...
Brad
Mugencrxsir1
Feb 26, 2006 04:17 PM
Ri5e
Aug 24, 2001 07:59 AM
