Is a lightweight flywheel really worth it?
I have a fairly built NA setup. Forged pistons and rods, 11:1 compression custom 400 lift cam. Currently I'm putting 186 to the ground. It's fun now, but sometimes I wonder if I might be able to free up another 5 hp or so by going to a lighter flywheel. With the cam I'm running, the engine really doesn't start making power until 3500 but once it does, it pulls all the way to redline which is currently 8100. Thoughts? Suggestions?
This is what i think since it has a less rotational mass the engine wont have to stress as much to turn it and it will rev quicker.As long as your not spinning your tires im sure the quicker revs will net you faster times.
I've got a JUN ultra light... I love it. I love the throttle response I get from it. Remeber, less rotational mass makes for a faster car. There was a formula in SCC a while back that showed how to compute mass reduced from the fly to convert it to lbs off the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeer »</TD></TR><TR><TD CLASS="quote">
im running the act prolite flywheel.......
thought i would change it out since i was doing the clutch anyways.</TD></TR></TABLE>
I'd never go back to stock. I wish I had my clutch and flywheel upgrade sooner. I absolutely love it. I actually wish I could run a lighter flywheel. There such thing as like a 4lb flywheel? lol
I'm getting that as well..Is it good ?? Sure hope so 'cause I just ordered it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ce »</TD></TR><TR><TD CLASS="quote">
i love mine. BTW its forged too!!!!!!
</TD></TR></TABLE>i love mine. BTW its forged too!!!!!!
anyone running a stock lightened flywheel , i have a very reputable shop that says they have done many b18a1 flywheels and have not had one scatter yet. also he said most of the weight is taken from the outside .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dattegbol »</TD></TR><TR><TD CLASS="quote">anyone running a stock lightened flywheel , i have a very reputable shop that says they have done many b18a1 flywheels and have not had one scatter yet. also he said most of the weight is taken from the outside .</TD></TR></TABLE>
Im running a stock lightened flywheel, and I love it. Its a LS shaved down to 10lbs
Before I added an aftermarket lightened flywheel, I was making a little less peak power than you, and noticed big difference with the new flywheel. The revs move much quicker. I'm currently using an AASCO 9lb'er
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheRedSkoolingBus »</TD></TR><TR><TD CLASS="quote">Yes it does make it lighter meaning that it rotates with less force meaning it makes it easier to rev the motor faster but ....
Doesnt it also make you lose Torque? </TD></TR></TABLE>
No..however it may feel that way because of the loss of momentum you get from the heavy stock flywheel
