flywheel or cam?
Old Apr 20, 2004 | 05:41 PM
Mr_Bojangles's Avatar
Default flywheel or cam?
I have a d16z6 with all the bolt-ons and a zex 75 shot. Which would be the best to go with a zex 59300 cam and valve springs, or a lightweight flywheel?
I can't decide hopefully you can help
Chris
Old Apr 20, 2004 | 06:34 PM
vr6 bia's Avatar
Default Re: flywheel or cam? (Mr_Bojangles)
well cams will actually make more power so im going to recommend the cams. light weight fly wheels are nice but with accleration they are barely noticable. the main thing your going to get out of a light weight flywheel would be with rev matcing.
Old Apr 20, 2004 | 10:32 PM
blackeg's Avatar
Default Re: flywheel or cam? (vr6 bia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vr6 bia &raquo;</TD></TR><TR><TD CLASS="quote">well cams will actually make more power so im going to recommend the cams. light weight fly wheels are nice but with accleration they are barely noticable. the main thing your going to get out of a light weight flywheel would be with rev matcing.</TD></TR></TABLE>
i beg to differ my friend. when i went from stock to act 12lb flywheel, my car revved much faster, making it quicker becasue i was in my powerband faster(especially helpful on the gutless low end of my d16). with that said, the cam will make you whp, and the flywheel will take time off your 1/4 mile. personally, i would get the cam and valvesprings, and then just get a light flywheel if/when you replace your clutch to someehing beefier. you will need something to raise you rev limit to 7800, cause thats when the cam stops making power, but make sure it dont advance your ignition timing making it possible to detonate while spraying
edit: 1000 posts y0! hahaha
LS94tegra
May 23, 2008 07:41 PM
hondamn1320
Nov 7, 2007 10:10 PM
phyzJunkieCivic
Sep 12, 2006 08:14 AM
romeirome1
Jan 15, 2004 02:55 PM
Mr. 1582
17
Sep 21, 2003 06:21 PM
