Intercooler piping. Mild steel or aluminum?
Old Jul 8, 2003 | 07:31 AM
MrCrx's Avatar
Default Intercooler piping. Mild steel or aluminum?
What is the better choice and why?
Old Jul 8, 2003 | 07:36 AM
Muckman's Avatar
Moderator in Chief
Default Re: Intercooler piping. Mild steel or aluminum? (MrCrx)
I think Aluminum is because its lighter and it cools better. At least the kit I bought came with aluminum piping...
Old Jul 8, 2003 | 07:37 AM
mos's Avatar
mos
Steel because you don't have to bend over to install it.
Old Oct 7, 2003 | 10:49 AM
gelok's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (mos)
I have same question. Please need more info
Old Oct 7, 2003 | 10:55 AM
ricodemus's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (redintegra_18)
how about aluminized steel from JCwhitney?
Old Oct 7, 2003 | 11:02 AM
R6Elmo's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (ricodemus)
Aluminum is better. Less chance or rust, and lighter.
Steel works just as well too.
Old Oct 7, 2003 | 11:08 AM
Soon_2b_evil's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (R6Elmo)
i was thinkin about using steel! i mean its a little heaveier but its cheaper.
Old Oct 7, 2003 | 11:25 AM
Happyman's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (Soon_2b_evil)
Whatever your blow off valve flange is :-P
Old Oct 7, 2003 | 11:36 AM
gelok's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (eh6turbo)
I have aluminum flange for my Blitz BOV so I'll just use aluminum then. Thanks
Old Oct 7, 2003 | 11:59 AM
BROOD's Avatar
Fabricating aluminum charge pipes are alot more work than steel though...esp if you can't TIG weld aluminum and have to have someone else do it for you. Just something to keep in mind.
Old Oct 7, 2003 | 12:00 PM
This One's Avatar
They dont make I/C's out of steel! Well for the most part.
Typically you would want to build piping out of aluminum for the heat dissapating characteristics, If its the intake path.
At least thats what i was under the impression of.
civperc's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (BROOD)
hmm, what would be the best choice if I'm going to stick weld my IC piping?
tia
Old Oct 7, 2003 | 12:04 PM
This One's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (untensadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untensadude &raquo;</TD></TR><TR><TD CLASS="quote">stick weld my IC piping?
tia </TD></TR></TABLE>
What are you nuts!
Old Oct 7, 2003 | 12:07 PM
BROOD's Avatar
Steel, would be the choice. Having someone MIG weld the pipes would yeild better results though (tubing wall thickness is pretty thin for stick welding).
Old Oct 7, 2003 | 12:15 PM
civperc's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (tHIS oNE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHIS oNE &raquo;</TD></TR><TR><TD CLASS="quote">
What are you nuts!</TD></TR></TABLE>
stick welding, sure why not?
I'll be stick welding my exhaust system including downpipe, which is different, I understand. But I figured I'd give the IC piping bend at my throttle body (d16y7) a try. I have a pre-fabbed charge pipe, so it'd just be for experimentation. heck, if it goes well, I may stick weld more of the IC piping.
Old Oct 7, 2003 | 12:18 PM
Burke's Avatar
Banned
the cooling benefits of aluminum piping is negligible in comparison to steel. if you can afford Al and have easy access to a TIG, then go ahead and get Al, but if you wanna save some bucks, then MIG together some mild steel and paint it if you want.
Old Oct 7, 2003 | 12:20 PM
Ricey McRicerton's Avatar
I'll be stick welding my exhaust system including downpipe, which is different, I understand. But I figured I'd give the IC piping bend at my throttle body (d16y7) a try. I have a pre-fabbed charge pipe, so it'd just be for experimentation. heck, if it goes well, I may stick weld more of the IC piping.</TD></TR></TABLE>
Id definatley swap over to the y8 IM before you do this Maybe that's just my opinion though.
Old Oct 7, 2003 | 12:34 PM
civperc's Avatar
Default Re: Intercooler piping. Mild steel or aluminum? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Id definatley swap over to the y8 IM before you do this</TD></TR></TABLE>
why do you say that? flow?
Old Oct 7, 2003 | 03:07 PM
Happyman's Avatar
Ya y8 flows much better than y7. Or get a skunk2. Get something. The y7 sucks
Old Oct 7, 2003 | 04:20 PM
civperc's Avatar
yeah I've been considering it. maybe I'll try to trade one of intake manifolds I'm selling, for a d16y8 manifold.
Old Oct 7, 2003 | 04:24 PM
5thgencivic's Avatar
I'm going to get a front mount intake kit and use the aluminum piping from that.
Old Oct 7, 2003 | 06:09 PM
turbotypeR@SPEC's Avatar
25 Year Member
agreed
b16bri
Sep 30, 2010 08:59 AM
b16bri
Welding / Fabrication
Sep 10, 2010 03:15 PM
mattyv
Nov 27, 2006 09:14 AM
Flamenco-T
Jun 7, 2006 02:46 PM
nerdsports
Mar 17, 2003 05:39 AM
