Ways to Up your boost...?
Old Jul 7, 2003 | 08:51 PM
boostdB16a's Avatar
Default Ways to Up your boost...?
I have a custom built turbo application...but i was lookin for ways to up your boost besides a controller....i heard about just putting a heavier spring in your wastegate but i wasnt sure how this workd? Are there any other ways?
Old Jul 8, 2003 | 12:16 AM
mskibbz-T's Avatar
Default Re: Ways to Up your boost...? (boostdB16a)
A) Build a manual boost controller from Home Depot parts (cheap)
B) Buy a WG spring that is designed for a higher boost level (~$45)
C) Buy a manual boost controller ($75+)
D) Buy an electronic boost controller ($200+)
Those are all the options that I can think of...
Old Jul 8, 2003 | 09:04 AM
Joseph Davis's Avatar
Default Re: Ways to Up your boost...? (mskibbz-T)
E) Insert a bleed orifice tee'd into the vacuum/boost line going to your wastegate.(cheap)
... and on a less contructive note...
F) Disconnect wastegate vacuum/boost line and control boost by feathering the throttle. (free)
Old Jul 8, 2003 | 09:36 AM
88ZCRX's Avatar
Default Re: Ways to Up your boost...? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">... and on a less contructive note...
F) Disconnect wastegate vacuum/boost line and control boost by feathering the throttle. (free)</TD></TR></TABLE>
lmfao. Thats a good idea, I am gonna have to try that
Old Jul 8, 2003 | 10:16 AM
boostdB16a's Avatar
how would you up from home depot?
Old Jul 8, 2003 | 11:29 AM
redteg87's Avatar
Apollo has a clearance going on. $15 for MBC's!
http://www.apolloracing.com/pr...aa4dc
Old Jul 8, 2003 | 05:42 PM
Boosted Gsr Hatch's Avatar
Default Re: Ways to Up your boost...? (redteg87)
if you have a delta gate you can loosen the allen bolt on top and get about 1-2 psi more
Old Jul 8, 2003 | 06:06 PM
stierhund's Avatar
http://www.boostvalve.com/pricelist.html
cheap, but u can build it for cheaper if you get it just right
also get a bigger downpipe if u want faster boost, I dont recommend goin up in boost if you have a stock bottom end, just get a bigger downpipe and be happier with a faster spooling turbo and working motor
Old Jul 8, 2003 | 06:10 PM
MiraiZ's Avatar
Default Re: Ways to Up your boost...? (stierhund)
remove WG...seal off wastegate flange....run exhaust directly into turbo...MAD POWER!!!!!!
ericstambaugh07
Jun 23, 2007 09:04 AM
xxscaxx
Feb 21, 2005 04:13 AM
thruvines87
Dec 6, 2004 10:00 PM
Meet07
Feb 3, 2004 10:45 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
