Check Engine Light with UBERTEG Chip Help!!
Hey I was testing my set up yesterday and it was running fine, not boosting (see below), I am running 440s and the uberteg chip.. anyways my question is: Do I still need to run check valves or a missing link because after about 10 mins of driving I get a CEL and the car dies out.. I just turn the key off and restart it and the cel light goes away and I can drive fine again.. is this because I need to run a missing link? The only reason I dont think i do is since I am not making boost can I still have this problem? TIA!
hey, you need to check and see what code your CEL is throwing.. also its a good idea to get in contact with the guy who you got the uberteg chip from as he may be able to help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedz »</TD></TR><TR><TD CLASS="quote">hey, you need to check and see what code your CEL is throwing.. also its a good idea to get in contact with the guy who you got the uberteg chip from as he may be able to help.
Will do, but do you think it has anything to do with me needing a missing link?? dosent make sense if im not making boost, right??
Hey I cant pull the code.. when i shut off the car and try the jumper on the service connector and turn the car back on the acc. the cel code stays on, it dosent blink. can someone tell me the steps to make sure im trying to pull the code right. Dont I:
(1994 Integra LS B18b 2dR)
get a cel when driving
turn car off
pull out blue service connector from green boot (under the glove box)
use a paper clip and jum between the female ends of the connetor
turn car on to accessory and count the lights to get the code?
If so, im doing this right just not getting a code.. HELP!!
the car just throws a code while driving and stalls
turn car off
ill check, i really dont know what im looking for though, dont know much in the field of electronics.. someone want to post a pic of what it should and should not look like
97gSrkId88
Mar 20, 2003 11:06 PM
