should i torque the clutch?
Old Jul 3, 2003 | 03:57 PM
AllMoToRB18c's Avatar
Default should i torque the clutch?
should i torgue the clutch on a gsr?.....its an act clutch with a stock flywheel....and if so how many lbs.?
Old Jul 3, 2003 | 04:11 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: should i torque the clutch? (AllMoToRB18c)
You should TQ anything on a car. That's just me.
Old Jul 3, 2003 | 04:12 PM
J2turbo21's Avatar
From what i remember the pressure plate is 19lbs and the flywheel bolts are 76lbs.I got that using the search button Im sure someone can confirm because 19lbs seems a little low but alot of threads i read said the same thing.
Old Jul 3, 2003 | 10:53 PM
y0sh1katu's Avatar
Default Re: should i torque the clutch? (J2turbo21)
i tq my plate to 20ft-lbs.
correct, flywheel is 76ft-lbs.
Old Jul 4, 2003 | 11:05 AM
raene's Avatar
If you don't torque the clutch, I guarantee it will not work right.
Watch what happens to the fingers when you tighten it down. If you don't have them all exactly even, at the same torque, you'll get shuddering engagement.
Old Jul 4, 2003 | 11:57 AM
riceboyEFsi's Avatar
many pros i know dont but i do because i had a pressure plate bolt back out on me and it destroyed a jdm y1 tranny w/ lsd
Old Sep 13, 2004 | 08:36 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: should i torque the clutch? (riceboyEFsi)
YES! 76 WITH LOCK TIGHT
Old Sep 13, 2004 | 08:41 AM
eyeamvic's Avatar
Default Re: should i torque the clutch? (BLUE EH3)
I had to drop a tranny just because the clutch bolts somehow got loose. Don't forget to use some loc-tite, it's a pain starting it up and then it not going into gear. I triple check now.
Old Sep 13, 2004 | 10:08 AM
hybrid_vtec's Avatar
19ft. lbs. I believe!
Old Sep 13, 2004 | 12:36 PM
chictunner97ex's Avatar
Default Re: should i torque the clutch? (hybrid_vtec)
yes the pressure plate torque is 19ft-lbs and the flywheel is 76ft-lbs. if you don't torque down the pressure plate then you don't get the fingers to press down or inward evenly, like they are supposed to. good luck
Old Sep 15, 2004 | 08:29 AM
Default Re: should i torque the clutch? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">If you don't torque the clutch, I guarantee it will not work right</TD></TR></TABLE>
u guarantee?....sure buddy...im sure it wont work right....i hit them on with a 3/8 drive mini air gun and they been working fine for over a year now....not one problem and thats racing the motor all the time...so guarantee that
Old Sep 15, 2004 | 08:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">YES! 76 WITH LOCK TIGHT</TD></TR></TABLE>
stop bringin up my old *** post....u dont even know what ur talkin about
Old Sep 15, 2004 | 09:24 AM
JDMjdawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMoToRB18c &raquo;</TD></TR><TR><TD CLASS="quote">
u guarantee?....sure buddy...im sure it wont work right....i hit them on with a 3/8 drive mini air gun and they been working fine for over a year now....not one problem and thats racing the motor all the time...so guarantee that</TD></TR></TABLE>
I've done a few clutch jobs before.....Air gun always seems to work fine for me. I only torque down really technical things, especially everything on the head.
Old Sep 16, 2004 | 06:22 AM
Default Re: should i torque the clutch? (JDMjdawg)
same here...and i torque the flywheel
Old Sep 16, 2004 | 05:27 PM
go2slo96's Avatar
From: im rubberband man, hondred grand in my hand man
just torque it down, you're already in there right? might as well do it right the first time than have to pull the tranny because a bolt backed out and tore **** up. save yourself a headache.
Old Sep 16, 2004 | 05:30 PM
johnzm's Avatar
Default Re: should i torque the clutch? (go2slo96)
they back out it sucks.
i accidentally torqued my pressure plate to 30 ft lbs LOL wooops!
oh well
Old Nov 13, 2004 | 10:02 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: should i torque the clutch? (johnzm)
come by tim, i got a boot leg helms
Old Nov 22, 2004 | 05:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">come by tim, i got a boot leg helms</TD></TR></TABLE>
Will i dont need to.....this post is like a 1 1/2 years old.....stop lookin up my old *** topics and replyin to them
reboosted
Oct 4, 2009 07:56 PM
drevinder
Jan 18, 2004 09:09 PM
EGhybridHB
Jan 5, 2004 06:17 PM
Kermit EK
Dec 28, 2002 07:24 AM
CivicEx95
Apr 24, 2002 10:50 PM
