code 17 obd1 Vehicle Speed Sensor
Old Jul 2, 2003 | 10:57 PM
deez nuts's Avatar
Default code 17 obd1 Vehicle Speed Sensor
check egine light throwing code 17. its the vss (Vehicle Speed Sensor) code i believe. could it be my cluster? because it kind of mess up and the mph is bouncing around. is that the problem my cluster?
Ivan's Avatar
senior gold member
Default Re: code 17 obd1 Vehicle Speed Sensor (ek4 fa sho)
what about your VSS?
Old Jul 2, 2003 | 11:00 PM
function83's Avatar
Default Re: code 17 obd1 Vehicle Speed Sensor (Ivan)
check your vss on your tranny. its on the back top part of the tranny.
has a harness plug hooked up to it.
Old Jul 2, 2003 | 11:01 PM
deez nuts's Avatar
Default Re: code 17 obd1 Vehicle Speed Sensor (djhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djhatch &raquo;</TD></TR><TR><TD CLASS="quote">check your vss on your tranny. its on the back top part of the tranny.
has a harness plug hooked up to it.</TD></TR></TABLE>checked it and it's plugged in correctly
Old Jul 2, 2003 | 11:05 PM
deez nuts's Avatar
can someone check if thats the right code for 17
Old Jul 2, 2003 | 11:07 PM
aw1234dude's Avatar
hey did you get that bolt fixed that was leaking?
Old Jul 2, 2003 | 11:09 PM
deez nuts's Avatar
Default Re: code 17 obd1 Vehicle Speed Sensor (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude &raquo;</TD></TR><TR><TD CLASS="quote">hey did you get that bolt fixed that was leaking?</TD></TR></TABLE>jb weld
Old Jul 2, 2003 | 11:13 PM
Ivan's Avatar
senior gold member
all it takes is a little search man here I found a thread with a link https://honda-tech.com/zerothread?id=540783.
17 is the VSS. even if its plugged in, it can be bad and thats what i think your problem is.
im_poor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 fa sho &raquo;</TD></TR><TR><TD CLASS="quote">can someone check if thats the right code for 17</TD></TR></TABLE>
its correct
Old Jul 2, 2003 | 11:17 PM
deez nuts's Avatar
Default Re: code 17 obd1 Vehicle Speed Sensor (im_poor)
damn i check the plug still check engine comes on
Old Jul 2, 2003 | 11:24 PM
Ivan's Avatar
senior gold member
your sensor is bad dude.
Old Jul 3, 2003 | 12:04 AM
im_poor's Avatar
did you try to reset the ecu....
ZakkWylde
Feb 21, 2008 10:33 AM
sireg6
Sep 26, 2006 01:38 PM
2-7offsuit
Jun 20, 2006 09:26 PM
7rrivera7
Nov 2, 2004 06:25 AM
klepsta
Jul 28, 2004 07:53 AM
