code 17 obd1 Vehicle Speed Sensor
check egine light throwing code 17. its the vss (Vehicle Speed Sensor) code i believe. could it be my cluster? because it kind of mess up and the mph is bouncing around. is that the problem my cluster?
Re: code 17 obd1 Vehicle Speed Sensor (djhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djhatch »</TD></TR><TR><TD CLASS="quote">check your vss on your tranny. its on the back top part of the tranny.
has a harness plug hooked up to it.</TD></TR></TABLE>checked it and it's plugged in correctly
Re: code 17 obd1 Vehicle Speed Sensor (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude »</TD></TR><TR><TD CLASS="quote">hey did you get that bolt fixed that was leaking?</TD></TR></TABLE>jb weld
senior gold member
Re: code 17 obd1 Vehicle Speed Sensor (ek4 fa sho)
all it takes is a little search man here I found a thread with a link https://honda-tech.com/zerothread?id=540783.
17 is the VSS. even if its plugged in, it can be bad and thats what i think your problem is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 fa sho »</TD></TR><TR><TD CLASS="quote">can someone check if thats the right code for 17</TD></TR></TABLE>
its correct
its correct
