Shift Linkage...
Old Jul 2, 2003 | 10:30 PM
nY's FiNeSt's Avatar
Default Shift Linkage...
Wassup, i just bought a gsr tranny and the kid had trouble taking the shift linkage off so he left it for me.
All i have to do is knock the "bitch" pin out and it comes off? Please help, thanks alot guys
Old Jul 2, 2003 | 10:33 PM
function83's Avatar
Default Re: Shift Linkage... (nY's FiNeSt)
find a punch the right diameter and your set. or if you wanna do it a hard way try a philips screwdriver.
Old Jul 3, 2003 | 12:45 AM
tangb2023
Guest
Posts: n/a
Default Re: Shift Linkage... (djhatch)
what he said.. also use a drill bit with right diameter.. a screwdriver can widen the pin
Old Jul 3, 2003 | 12:52 AM
Kamin's Avatar
Default Re: Shift Linkage... (tangb2023)
8mm NON TAPERED punch.
i have a drill bit i use.
works like a charm every time.
Old Jul 3, 2003 | 12:53 AM
youngkow's Avatar
I tried using a drill bit, and it didn't work because the point just made the pin expand more. Best thing to do is find a 8mm punch, readily available at your local hardware store.
Old Jul 3, 2003 | 05:42 AM
monicle's Avatar
Do NOT try to use a phillips head screwdriver as posted a bit earlier. I tried it and got this. Getting the bastard back out after it pushed itself through the pin was a hooker. Especially after the screwdriver handle came off. (yeah cheap screwdriver)
Old Jul 3, 2003 | 09:49 AM
Default Re: Shift Linkage... (monicle)
the tranny is off the car already, i don't know what i'm going to try and use to take this ****** out, maybe a screw driver because i don't have that drill bit
Old Jul 3, 2003 | 09:59 AM
and i have to go from the bottom up right?
Old Jul 3, 2003 | 10:01 AM
jetli6969's Avatar
New User
Naw you can go from top to bottom if the motor is already out. DO you have an air compressor? IF so go get an air hammer, problem will be solved. IF not ughh good luck
Old Jul 3, 2003 | 11:08 AM
Default Re: Shift Linkage... (jetli6969)
i just got it out, i used a screw driver and just banged it out, took like 5 minutes but finally came out. Thanks for everyones help
Old Jul 3, 2003 | 12:39 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt &raquo;</TD></TR><TR><TD CLASS="quote">i just got it out, i used a screw driver and just banged it out, took like 5 minutes but finally came out. Thanks for everyones help </TD></TR></TABLE>
You're probably going to need a new spring pin because that one is probably mangled to hell and back.
Old Jul 3, 2003 | 12:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Shift Linkage... (PatrickGSR94)
the correct i tool is a roll pin punch, use a 3m tapered. but i am standind on the floor with the car in the air it is a little easier. but a roll pin punch has a nipple that sits in the center os the pin as you hit it with the hammer.
Old Jul 3, 2003 | 01:00 PM
MAD ITR 55's Avatar
I always use a A/C Compressor bolt.I found that to work good because it has a pointed end that fits perfectly into the "bitch" pin.Then the 12mm head of the bolt profides enough width to get a good hit on it.
Old Jul 3, 2003 | 01:10 PM
ill phil's Avatar
Default Re: (V8s2shame)
You can also use a socket with and extension on it and it works very well. I believe its something really small like a 5mm, but I use a standard sized equivalent.
Old Jul 3, 2003 | 01:11 PM
Nextelbuddy's Avatar
Default Re: Shift Linkage... (boostedcivicsir)
i use this tool as well and it is absolutely the best and fastest
Old Jul 3, 2003 | 08:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
You're probably going to need a new spring pin because that one is probably mangled to hell and back.</TD></TR></TABLE>
actually the one i got out is perfect, it slid out with no problems, i was just tapping lightly so nothing would happen. That's why it took 5 minutes, haha
Mugencrxsir1
12
Jul 6, 2010 04:58 PM
Matt_Jagg7
May 13, 2010 01:18 AM
z6hatchboy
16
Aug 6, 2009 07:59 AM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
MR. MIYAGI
Mar 12, 2004 12:34 PM
