POST your motor SETUPS, times & dyno #'s as well (for reference use)
Old Jul 2, 2003 | 09:39 PM
untitled's Avatar
Default POST your motor SETUPS, times & dyno #'s as well (for reference use)
i thought we should have a thread with everyones setups, dyno #'s, and 1/4 times so we could keep the "how much power will i be making" and "what times will i run with this setup" questions to a minimum. LS/vtec, b20/vtec, poor man R, gsr, etc etc..
Old Jul 2, 2003 | 10:38 PM
B00ST2nR's Avatar
Default Re: POST your motor SETUPS, times & dyno #'s as well (88crx91integra)
2000 GS-R with:
Skunk2 Stage 1 cams and cam gears
Skunk2 Intake Manifold
I/H/E
VAFC / B&M FPR
171.2wHP on Stock TB, Stock ECU, Stock Valvetrain, and Stock Cat Converter. I'll be swapping all those stock parts out and Dyno tuning it hopefully soon. I'll let you know how much power I push then...
Old Jul 3, 2003 | 12:56 AM
Richard.'s Avatar
Default Re: POST your motor SETUPS, times & dyno #'s as well (Skunk2nR)
https://honda-tech.com/zerothread?id=541008
alot of them are on there ^
Old Jul 3, 2003 | 12:49 PM
lsvtecracer's Avatar
My old ls/vtec setup:
1991 ls block with pr3 pistons
b16 oil pump
stock 81mm bore
2nd generation b16 head
type R intake cam
skunk 2 manifold
jdm dc 4-1 header
msd ignition
I had p28 ecu wtih pyr chip and v-afc
I dyno at 174 whp and 123 lbs of torque. I ran 14.4 @97 mph in a 2600 lbs del sol (with driver) on street tires. My best 60' was a 2.25.
Old Jul 3, 2003 | 01:04 PM
MaxBoost's Avatar
New User
Default Re: POST your motor SETUPS, times & dyno #'s as well (lsvtecracer)
95 DX Hatch
B18c1 / B16 tranny
AEM ITR CAI
JDM DC Headers
Custom 2.5" MB Exhaust
Street Tires
160whp in 99% humidity 95 degree weather..
13.91@99mph weighing in at 2075lbs.
Old Jul 3, 2003 | 11:50 PM
F1Spec's Avatar
Default Re: POST your motor SETUPS, times & dyno #'s as well (MaxBoost)
ls/vtec
11.3:1 pistons
ctr cams
hytech header
189whp/139wtq
12.9@105mph (1.9 60ft time)
~2400lbs integra with me in it.
Old Jul 4, 2003 | 01:19 AM
98itR484's Avatar
Default Re: POST your motor SETUPS, times & dyno #'s as well (s2geezy)
1998 ITR
Stock intake
Stock head (stock cams 1998 ITR cams/camgears etc etc )
stock ecu (no vafc, no tuning)
Stock timing
SMS header
Carsound Cat
Custom 2.5inch exhaust to Spoon n1 muffler
187hp/126tq
Have dyno graph to prove. (also been posted here on HT)
Old Jul 4, 2003 | 06:40 AM
rainmanEK's Avatar
big strong guy
Default Re: POST your motor SETUPS, times & dyno #'s as well (PacMan ITR)
Gsr block
ITR head
~11.3 ish compression
Skunk Stage 1 Cams
DC JDM 4-1
2.5" exhaust
ITR everything else (ie..TB, IM, etc..)
199.7WHP and 135tq
Corrected on a Dyno-Jet
Eric
BMo Tuning
13
Feb 7, 2008 12:42 PM
MiKeAhOwSkI
28
May 1, 2005 11:34 PM
project civic
Feb 26, 2005 06:33 AM
Cjsls
15
Jan 29, 2005 07:32 AM
Hondasaurs
Aug 26, 2003 04:16 PM
