skunk2 short shifter, not short anymore?
Old Jul 2, 2003 | 07:16 PM
Loveless's Avatar
Default skunk2 short shifter, not short anymore?
well I installed the short shifter last weekend, and I don't know when but it stopped feeling short and start to feel very much like stock
what happened?
I don't have any jack/tools at my apartment so I see myself
anyone know what could hae ahppened?
Old Jul 2, 2003 | 08:11 PM
skygtr01's Avatar
Default Re: skunk2 short shifter, not short anymore? (Loveless)
You got use to it.
Old Jul 2, 2003 | 08:14 PM
Lord Helmet's Avatar
Default Re: skunk2 short shifter, not short anymore? (skygtr01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skygtr01 &raquo;</TD></TR><TR><TD CLASS="quote">You got use to it.</TD></TR></TABLE>
I'll repeat that again: You got use to it
I know I did.
Old Jul 2, 2003 | 08:29 PM
Loveless's Avatar
Default Re: skunk2 short shifter, not short anymore? (sleeperciv)
no, trust me, it toally went back to stock feeling. I am VERY sure of it
is it possible that the lock nut fell out? and that the shifter is holding on to the linkage by the nut thread?
But I locked it down good with a racket and a hext key
Old Jul 2, 2003 | 08:40 PM
95 integra's Avatar
Somebody stole your short shifter and put a stock one back in
Old Jul 2, 2003 | 11:08 PM
ambiguous's Avatar
the skunk2 short shifter isnt that short to begin with, thats not a bad thing - i find its the perfect balance!
Old Jul 3, 2003 | 12:32 AM
eg6sir-s's Avatar
people seem to think that short shifters are meant to shorten the throw and height. some short shifters have adjustable height but majority of all short shifters are meant to reduce the throw by a few percent from stock. skunk2 shifters are actually one of the best around...as for its height it will sit taller than stock to some chassis more than others. trust me that throw is shorter with the skunk2 in your car its just sometimes the power of suggestion gets out of hand.
Old Jul 3, 2003 | 01:22 AM
p1ccoloz's Avatar
Default Re: skunk2 short shifter, not short anymore? (eg6si)
i think you got used to it....
Old Jul 3, 2003 | 01:57 AM
xteg95's Avatar
Default Re: skunk2 short shifter, not short anymore? (p1ccoloz)
unless its loose its not possible to "go back" to stock length w/a SS. like everyone else is saying...first off the skunk2 isn't a HUGE shorter throw and you probably go used to it, after a month w/my SS i could barely tell the difference anymore
Old Jul 3, 2003 | 01:59 AM
mskibbz-T's Avatar
WTF
Old Jul 3, 2003 | 05:16 AM
HondaIntegraLS's Avatar
Default Re: skunk2 short shifter, not short anymore? (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">WTF </TD></TR></TABLE>
post ***** much?
Old Jul 3, 2003 | 05:34 AM
IntEGNYC's Avatar
You shoudl have compared the two shifters prior to installation. That would give you a sense of whether the pivot point was higher or lower than the new shifter.
Old Jul 3, 2003 | 08:02 AM
Loveless's Avatar
Default Re: skunk2 short shifter, not short anymore? (IntEGNYC)
I don't think I gotten use to it THAT fast.
I installed it last weekend and it was short and stiff
I don't know when but probably tuesday I stopped feeling it all together.
I know my stock shift feeling and I am aware how my short shifter feels after 2 days of shifting.
Now it's long and easy to shift (not stiff anymore)
Old Jul 3, 2003 | 08:33 AM
eg6sir-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">I don't think I gotten use to it THAT fast.
Now it's long and easy to shift (not stiff anymore)</TD></TR></TABLE>
did you use energy suspension bushing kit?
Old Jul 3, 2003 | 03:51 PM
Loveless's Avatar
yes I got the es bushing but I only install the rear, the front bushing was too hard to fit into the linkage
Old Jul 3, 2003 | 04:33 PM
eg6sir-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">yes I got the es bushing but I only install the rear, the front bushing was too hard to fit into the linkage</TD></TR></TABLE>
maybe thats the discomfort in your shifting?
Old Jul 4, 2003 | 09:19 PM
Loveless's Avatar
I crawled under the car to look, nothing out of ordinary.
I didn't work on it though, going to take everything apart and put them back to see if that helps
the shifter nut is in place, but I do hear funny sound when I shift
Old Jul 4, 2003 | 11:28 PM
skunk2civicsi's Avatar
Default Re: (ambiguousasn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambiguousasn &raquo;</TD></TR><TR><TD CLASS="quote">the skunk2 short shifter isnt that short to begin with, thats not a bad thing - i find its the perfect balance! </TD></TR></TABLE>
i agree. it isnt that short, but it just feels great to shift. almost like the shifter just falls into gear.
Old Jul 5, 2003 | 11:29 AM
HulkSmash's Avatar
Default Re: (skunk2civicsi)
you prolly overtightened the nut on the shifter to the linkage.
Old Jul 5, 2003 | 11:35 AM
Havokmkr's Avatar
Default Re: (HulkSmash)
You might want to take your time and install the front bushing too. Might as well while you got it all apart anyway.
Old Jul 5, 2003 | 07:13 PM
mskibbz-T's Avatar
Get some white lithium grease(Shucks, Sears, etc.. ~$2) and lightly coat the poly bushing. Lay the linkage on the ground on its side and put the new busing on top of where it needs to go. Use something to slowly push it in and use your fingers to make sure that you don't lose your progress, move slowly around the circular shape pushing it in bit by bit and then putting pressure down with your fingers to maintain the progress. A socket wrench worked great for me. Good luck!
tigueremalo
Oct 30, 2007 07:32 PM
Han Solo
Jan 8, 2007 01:01 PM
ieatrice
Aug 1, 2004 09:04 PM
GReddy SI
May 15, 2004 09:56 AM
