how do you know if you have a bent valve?
Old Jul 2, 2003 | 12:19 PM
JdmIntegra98's Avatar
Default how do you know if you have a bent valve?
if u have a bent valve.. what happens.. and how can u know?
Old Jul 2, 2003 | 12:36 PM
216.226.142.95:27016's Avatar
Default Re: how do you know if you have a bent valve? (JdmIntegra98)
you can tell by
do a compression test
the car has bad idle, it fluctuates
it can run then just stall
rattling sound in the engine
car runs like ***
there is more but im no pro at this so do a search for more accurate answer
Old Jul 3, 2003 | 08:18 AM
Witty's Avatar
Default Re: how do you know if you have a bent valve? (216.226.142.95:27016)
What do you have to do to check? Pull the valves and take them to a machine shop?
Old Jul 3, 2003 | 08:24 AM
GSpeedR's Avatar
Default Re: how do you know if you have a bent valve? (Witty)
A leakdown test is probably a better way to determine whether you're leaking through the valves.
Old Jul 3, 2003 | 08:55 AM
JL 74's Avatar
25 Year Member
Not another misshift I hope.
1 3 5
2 4 R
Old Jul 3, 2003 | 12:08 PM
how much is a leakdown test... and like where can i get it?
Old Jul 3, 2003 | 02:58 PM
Stewie's Avatar
Default Re: (JdmIntegra98)
Where are you located?
Old Jul 3, 2003 | 03:58 PM
memphis tn
B20inDCinLBC
Oct 21, 2006 09:40 PM
RGoose18
May 21, 2004 10:13 AM
BamaGSR
Mar 29, 2004 07:16 PM
2000CX
Oct 28, 2003 06:26 PM
Ryan C
Jul 25, 2003 10:13 AM
