Coolant Problem!! Please help!
Old Jul 2, 2003 | 12:04 AM
Type Wah's Avatar
Default Coolant Problem!! Please help!
Ok, something's up with my coolant container, the white container under the hood by the radiator. Well I filled it up to Max level yesterday, and this afternoon i checked it and it was empty.. I mean, sucked dry.. i removed the container and i felt the bottom of it, and it was wet.. like its leaking.. where can i get a replacement container?
cheap
Old Jul 2, 2003 | 03:02 AM
Henry HA's Avatar
HAnda-Tech Member
Default Re: Coolant Problem!! Please help! (Type Wah)
Is your radiator full?
Old Jul 2, 2003 | 05:25 AM
slomob18b's Avatar
Take out the coolant overfill resorvoir (the white bottle) and clean it dry. Then fill it with some water to see if it leaks. If not, then you radiator might have a leak somewhere. Check the top seal of the radiator to see if it is leaking and the hoses as well.
Old Jul 2, 2003 | 05:58 AM
spd18's Avatar
Default Re: Coolant Problem!! Please help! (slomob18b)
my car had the same problem of losing coolant.. but the problem was the seal on the top of my radiator had broke loose and coolant seeped out of it whenever i drove. apparently that was a pretty common thing to happen on integra radiators. i got it replaced by acura in the last week of my warrenty, luckily. do you smell burning coolant when you drive the car? or what about when you park somewhere, do you see a large puddle under where the radiator/reservoir is?
Old Jul 2, 2003 | 08:45 AM
Type Wah's Avatar
I don't think its my radiator because the bottom of the coolant resevoir bottle is wet, like there must be a leak in it... I put some duct tape temporarily to see if that will help hold in some coolant, but its now soaked so it has to be leaking... I'm gonna try to replace the container, but I need help finding one... If anyone can sell me one for cheap or link me to where I can buy it, i would appreciate it...
Thanks
Old Jul 2, 2003 | 09:02 AM
spd18's Avatar
Default Re: (Type Wah)
you can pull out the reservoir from the car and take it in your house, dry it off, fill it, and see if it leaks. if not its something else. i'd do that before buying a new one.
Old Jul 2, 2003 | 09:08 AM
JL 74's Avatar
25 Year Member
Default Re: (spd18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spd18 &raquo;</TD></TR><TR><TD CLASS="quote">you can pull out the reservoir from the car and take it in your house, dry it off, fill it, and see if it leaks. if not its something else. i'd do that before buying a new one.</TD></TR></TABLE>
Do what he said then let us know.
Old Jul 2, 2003 | 09:39 AM
Type Wah's Avatar
Default Re: (jl74)
OK, I just did that... it leaks mins right after i filled it
Old Jul 2, 2003 | 09:44 AM
JL 74's Avatar
25 Year Member
time to go to dealer and pick one up.
Old Jul 2, 2003 | 09:46 AM
Type Wah's Avatar
Default Re: (jl74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jl74 &raquo;</TD></TR><TR><TD CLASS="quote">time to go to dealer and pick one up.</TD></TR></TABLE>
But that's an hr drive... and I have to be at work at 3..
There's a Honda dealer thats local, but would they have parts for an Integra? I don't see why not, since its a Honda Motor...
Old Jul 2, 2003 | 09:48 AM
JL 74's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type Wah &raquo;</TD></TR><TR><TD CLASS="quote">
There's a Honda dealer thats local, but would they have parts for an Integra? I don't see why not, since its a Honda Motor... </TD></TR></TABLE>
Just post in the Classifieds here, you never know, someone might have it for cheap. Just bring a gallon of water with you and keep your radiator full for now and keep filling the reservoir if it is a very slow leak.
Old Jul 2, 2003 | 09:52 PM
Type Wah's Avatar
Default Re: Coolant Problem!! Please help! (B18C_DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Is your radiator full?</TD></TR></TABLE>
Yes, its full.. i'll check again in the morning
Old Jul 2, 2003 | 11:15 PM
Dased530's Avatar
I got a 96 teg, 93 civic and my mom has an 91 accord and I can almost swear that all three coolant resivour containers are the same size,... any wrecking yards near you ?
Sl0wH0nda
Jun 13, 2013 10:22 AM
keanevann2005
Sep 1, 2006 11:46 AM
Tim.
17
Jan 30, 2006 09:17 PM
Smeeg Heed
Aug 10, 2004 08:18 AM
Ri5e
Mar 18, 2002 03:39 AM
