Does 135- 150 psi compression test sound like ultra low compression?
Old Jul 1, 2003 | 06:15 PM
QCKGSR's Avatar
Default Does 135- 150 psi compression test sound like ultra low compression?
i just did a compression test on my b16b boosted for like 2000 miles. #1 135, 2- 145, 3- 145, 4- 150 those sound low especially when a buddy of mine has 9:1 and his come up at 180....
Old Jul 1, 2003 | 08:09 PM
the DR.'s Avatar
Default Re: Does 135- 150 psi compression test sound like ultra low compression? (QCKGSR)
that does sound low, did you do the test with the engine at WOT ?
Old Jul 1, 2003 | 08:10 PM
eg_type_r93's Avatar
thats average 90 is low
Old Jul 2, 2003 | 07:49 PM
Muckman's Avatar
Moderator in Chief
Default Re: (eg_type_r93)
is there anyway to calculate compression ratio from a compression test?
Old Jul 6, 2003 | 09:08 PM
civicsitek GanGsTa's Avatar
Default Re: (Muckman)
you said you have a b16b correct...ok your compression test should show numbers closer to 210. 135 is way off the mark for a b16b...way off
Old Jul 8, 2003 | 05:55 PM
StorminMatt's Avatar
Default Re: (civicsitek)
Try a different gauge. Gauges can be off quite a bit and cause wierd readings like this. Maybe try using your buddy's gauge that read 180psi on his 9:1 engine.
Old Jul 8, 2003 | 06:15 PM
irev210's Avatar
thats REALLY bad
on a 10.8 compression motor, you should be putting between 200-300 depending on which gauge u use
Old Jul 8, 2003 | 06:35 PM
quik1's Avatar
Default Re: Does 135- 150 psi compression test sound like ultra low compression? (irev210)
They are all within 10 - 15 % of each other sounds like the gauge is bad.
Old Jul 11, 2003 | 04:05 AM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">thats average 90 is low</TD></TR></TABLE>
for a 10.8 compression motor, thats not average
try a different gauge and make sure you follow this testing method-
1) make sure car is at operating temp
2) remove ECU fuse
3) some people say remove intake for better results
4) press gas petal all the way down
5) turn motor over 4 times
6) read result
repeat for other cylinders
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
Tad
Jun 27, 2005 12:04 AM
snowblind7x
Apr 13, 2005 08:12 PM
Nikoli
Oct 3, 2004 02:33 PM
Petah
Aug 19, 2003 11:37 PM
