Wheel bearing replacment problem....
Old Jul 1, 2003 | 05:35 PM
BrandonClaps's Avatar
New User
Default Wheel bearing replacment problem....
I removed the wheel bearing/hub assembly from the spindle in the rear, and part of the bearing/hub that is covering the ball bearings is stuck on the spindle. I tried heating it up and hitting a screwdriver between the peace and the trailing arm (i think thats what its called) and it didn't budge at all... What do i do?
Old Jul 2, 2003 | 06:54 AM
New User
Default Re: Wheel bearing replacment problem.... (BrandonClaps)
ttt
Old Jul 2, 2003 | 01:52 PM
New User
dfd
Old Jul 2, 2003 | 05:33 PM
MattD@Stoptech's Avatar
So did j00 remove it or is it stuck?
The two are contradictory...
Old Jul 2, 2003 | 07:46 PM
New User
Default Re: Wheel bearing replacment problem.... (El Pollo Diablo v3.5)
i removed the bearing/hub assembly, but there is a metal peiece inside the the hub which covers the ball bearings that is stuck on the spindle that i can't get off
Old Jul 3, 2003 | 02:27 AM
kkim's Avatar
https://honda-tech.com/zerothread?id=213106
https://honda-tech.com/zerothread?id=312966
hope these help.
rexload
Jun 5, 2015 11:31 AM
Creator
Apr 14, 2011 06:03 AM
alexb18c1
Sep 24, 2008 05:25 PM
eatsleepjaydiem
11
Jan 8, 2007 08:56 PM
low430
Aug 29, 2005 08:32 AM
