ITR spring rate... best way to have it?
Old Jul 1, 2003 | 06:49 AM
LudeToAHatch's Avatar
Default ITR spring rate... best way to have it?
Basically, I want the Tein RAs with the ITR spring rate for my 93 hatch but I'm not sure which is the best way to go about this. I hear of many people that have coilovers from an ITR and use the ITR rear lower control arms to make them fit. What's the benefit if any from doing this rather than just ordering the springs with the ITR rate for a civic? Do the ITR rear control arms benefit in handling over the civics'?
Old Jul 1, 2003 | 06:57 AM
2000blackgsr's Avatar
Default Re: ITR spring rate... best way to have it? (LudeToAHatch)
ITR control arms are stronger/lighter than the Civic arms.
Old Jul 1, 2003 | 07:02 AM
Default Re: ITR spring rate... best way to have it? (96coupe)
Thanks!
Old Jul 1, 2003 | 08:50 AM
BeerMan's Avatar
You might want to get ITR lower control arms (or even GSR) anyway. It will help with handling, indirectly; ITRLCA's allow you to put on an ITR tie bar and sway bar.
Also, New control arms with bushings makes the install 200% easier. There one particular suspension bolt that siezes very badly on most cars ( its the one in the middle of the LCA, don't know what its called); you can avoid it completely if you put in different LCA's. It makes the rear suspension even an easier piece of cake.
Old Jul 1, 2003 | 09:15 AM
euclid's Avatar
Default Re: ITR spring rate... best way to have it? (BeerMan)
i have tein ra's for sale, itr rear lca's included for $1150 shipped, they will bolt up directly to your hatch, no modifications. lmk
Old Jul 1, 2003 | 11:36 AM
Default Re: ITR spring rate... best way to have it? (euclid)
You got PM
Old Jul 2, 2003 | 06:52 AM
I was looking online and noticed Function 7 makes aluminum type-r lcas. What do you guys think of those in comparison to the oem R ones?
rsa0905
Suspension & Brakes
Jan 20, 2011 08:06 PM
eg_srbin
Jul 18, 2004 10:30 AM
nikolai.
Nov 10, 2003 03:54 PM
S&P500ITR
Jul 20, 2002 09:11 PM
