Can a noob install a 4 channel amp??
Old Jun 30, 2003 | 04:36 PM
Halo's Avatar
Default Can a noob install a 4 channel amp??
I just got my kicker kx 600.4 and am debating if I should just try to install the dam thing myself. I have a 4 guage kit and I know that red obviously connects to the battery...black to a chassis ground and yellow is my remote. The rca's are what confuse me, do I need to take the headunit off(Alpine 7894) to access the rca's? Are there any websites that go step by step with pictures how to install everything? My car is a 97 Civic with MB Quart QSD 6.5 in doors and Alpine Type-R 6x9's in back
Old Jun 30, 2003 | 05:07 PM
JOMO_
Guest
Posts: n/a
you could do it yourself but it is risky!
you need to take out the radio and plug in the rca's and run a remote wire (ussually blue) to the amp as well
then run the power wire, ground wire and remote wire to the amp, speaker wire as well and turn down all the gains
turn up gradually but be careful..
tell you the truth, you can make ALOT of mistakes that can be FATAL!
just do what i do, make sure you have installer friends!
Old Jun 30, 2003 | 05:09 PM
PetroGuyX's Avatar
very simple bro, no matter what you'll need to take the headunit out, what you're gonna do is, cut all 4 speakers from the wiring harness to the radio harness, run 4 new sets of speaker wire to the amp, you'll need your headunit out to access the rca inputs on your headunit anyway, and you'll hook your yellow remote wire to the blue with a white stripe on the alpine harness, that's pretty much all you need to know, and i dont really think a 4 guage kit was necassary for that amp, but hey, better safe than sorry, let me know if you need help taking the head unit out
Old Jun 30, 2003 | 06:37 PM
loki2323's Avatar
Default Re: (PetroGuyX)
its not that bad..I just finished re-wiring my entire car with larger gauge wire....worst friggin part is having to drill the plugs in the front doors to be able to run the speaker wires for the front components!!! took almost 2hrs the first door..I ran into lots of problems...second was a breeze
no if I can just get rid of this stupid engine noise in my speakers I'll be happy
Old Jun 30, 2003 | 07:21 PM
PetroGuyX's Avatar
engine noise eh, sounds like you need to run your rca's on opposite side as your power wire
Old Jul 1, 2003 | 05:54 AM
loki2323's Avatar
rca's are on the opposite side as the power wire
I used my seat belt bolt from the back seat as the ground point....sanded all the paint off the area...so I am thinking I may have too long of a ground so I will be moving it
Old Jul 1, 2003 | 07:38 AM
clm's Avatar
clm
Default Re: (loki2323)
It's not too bad, just time consuming. I spent about 7 hours (first time) doing mine so I could it the right way and hide everything. I did a "how-to" on the install of my del Sol that may also give you an idea.
Crutchfield has some good information.
Old Jul 2, 2003 | 07:09 AM
LSVtechnologytur...'s Avatar
Default Re: Can a noob install a 4 channel amp?? (Halo)
i just installed my first amp (4channel) over the weekend. Its not too bad, just make sure you read directions and take your time.
Old Jul 2, 2003 | 07:41 AM
nOOber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loki2323 &raquo;</TD></TR><TR><TD CLASS="quote">I used my seat belt bolt from the back seat as the ground point</TD></TR></TABLE>
Measure impedance vs. the negative post on the battery and that point in the car. I think you will find it rather high.
Old Jul 2, 2003 | 08:26 AM
loki2323's Avatar
Default Re: (nOOber)
yeah thats why I need to relocate it....how about the few bolts that are right in the spare tire well?
Old Jul 2, 2003 | 08:35 AM
nOOber's Avatar
Hmm, spare-wells are usually rusted out a bit.
Try a bit higher up on one of the sides of the trunk ( behind a plastic panel, if possible), where there may be less chance of rust.
To find the best spot, use your DMM to find the lowest impedance spot, back there.
Old Jul 9, 2003 | 08:59 PM
Jaesung's Avatar
what's dmm?
Old Jul 9, 2003 | 10:09 PM
DownBoyDown's Avatar
Yeah I think that you should do it yourself. Half the point of working on your car is to learn about the car and how fix/install things youself. Its not that hard. Just do some research first
Old Jul 10, 2003 | 05:21 AM
o_Rage_o's Avatar
Default Re: (DownBoyDown)
whatever you do, take your time, and make sure you don't have engagements that day/weekend you choose to do it.
A 4 chan amp install takes time - especially if your running new speaker wire.
It'll be worth it in the end Here's to self installs
-Rage
Old Jul 10, 2003 | 06:34 AM
PetroGuyX's Avatar
Default Re: (o_Rage_o)
i installed my 2 channel last night, i already had everything ran, i have a memphis 180x2, i bought it for 20 bucks, it looks brand new, badass man, you'll be VERY happy when you get it hooked up
Old Jul 10, 2003 | 06:39 AM
clm's Avatar
clm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_Rage_o &raquo;</TD></TR><TR><TD CLASS="quote">whatever you do, take your time, and make sure you don't have engagements that day/weekend you choose to do it.</TD></TR></TABLE>
Exactly. I started a Friday evening, worked until about 2 in the morning, and then worked the next dayfor 3 or 4 hours. It took a long time, but it was my first amp install and I wanted it done right.
Patience is a virtue when installing an amp.
Old Jul 10, 2003 | 04:04 PM
mattduskater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loki2323 &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats why I need to relocate it....how about the few bolts that are right in the spare tire well?</TD></TR></TABLE>
the best way to ground your amp is to find a close ground that is already there (check around tail lights or other electronics), and if you cant find one make one. I had to drill a small hole in the wheel well of my hatch and use a screw and some washers. also make sure you have plenty of grounds to your body to make sure the negitave (-) power can flow back to the battery just as fast as the positave (+) is leaving for better sound
Old Jul 10, 2003 | 04:47 PM
Taiyed's Avatar
Default Re: (Jaesung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaesung &raquo;</TD></TR><TR><TD CLASS="quote">what's dmm?</TD></TR></TABLE>
Digital
Multi
Meter
used to measure electronical **** such as impedance, voltage, and Amperage...expensive ones also do other fun **** like they can check AC frequency and make ham sandwiches...
Hatesmakingaccs
17
Oct 6, 2014 08:15 PM
05CivicSE
Audio / Security / Video
Mar 13, 2006 10:32 AM
boostincoupe
Oct 6, 2005 05:19 PM
another_crx
Dec 28, 2003 06:39 AM
JOMO
May 7, 2003 07:30 PM
