How To Install Remote For MultiAmp Setup
Old Dec 27, 2003 | 06:56 PM
another_crx's Avatar
Default How To Install Remote For MultiAmp Setup
Will be my first system install coming up this week. Have everything else worked and figured out for my 2 amp setup.
Only thing I am unsure of is how to run/wire a remote?
The remote is what turns the amps on and off right?
The (green) wire that was included in my amp kit goes directed from my amp and I splice it into what wire in the back of my deck?
Does it matter that I am going to be splicing 2 remotes into the same wire into the back of my deck? Should I connect the two remote wires from my amp at the same point in the wire on the back of the headunit so all 3 are kind of touching or different parts?
Old Dec 27, 2003 | 11:14 PM
1985 civic's Avatar
if you have an aftermarket deck, the remote wire is usually blue sometimes with a white stripe. run one wire from the deck, back to where the amps are then you can split it. its alright to split the remote wire because it just sends a signal to turn on the amp. you wont sacrifice any power or anything.
Old Dec 28, 2003 | 02:14 AM
Xsi's Avatar
Xsi
Check your headunit instructions for details on how many amps you can run off the remote wire. My sony deck is supposed to only have one at a time but the remote can run three no problem.
If you run into problems with the headunit not having enough power to turn them on then use a relay.
It's safe to join the three wires at the same place but make sure no wire is exposed.
Old Dec 28, 2003 | 06:39 AM
Default Re: (Xsi)
thanks guys
bopbop93030
Audio / Security / Video
13
May 5, 2009 11:08 AM
kcivicboi
Feb 23, 2006 11:26 AM
boostincoupe
Oct 6, 2005 05:19 PM
ChaosUnbound
Feb 24, 2004 04:20 PM
Understeer
Apr 18, 2003 09:15 PM
