d16z6 pulley marks. need to know wich 1 is wich..
the marks on my pulley have no color anymore so i need to find out wich 1 is the red and the white 1. here is how they look :
no red no right? ???? ???? not sure wich 1 is the white 1........
pls help .. remember the engine its a d16z6
If i remember there should be only 4 marks on your setup. The white one by itself and then counter-clockwise from it about 1/4 crank pulley is a cluster of 3. Of the three set, the one closest to the firewall is 14deg, middle is 16deg, and one closest to the front of the car is 18deg.
the mark furthest away from the 3 marks is the white mark. Even if you use the other mark, it will still line up at TDC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If i remember there should be only 4 marks on your setup. The white one by itself and then counter-clockwise from it about 1/4 crank pulley is a cluster of 3. Of the three set, the one closest to the firewall is 14deg, middle is 16deg, and one closest to the front of the car is 18deg.
There is actually 5 marks....the 18 degree, 16 degree and 14 degree timing marks, and the white TDC mark with another mark which is 2 degrees cam timing from that. Either of the 2 will work and line the #1 and 3 pistons at TDC...
puk
Aug 16, 2006 05:24 AM
