Harness help - brand and source
I did do a search first... so don't give me any of these...
I need a 5 point harness to fit a Sparco Rev Seat... car will have a full rollcage. What is a good harness and price and source?
Thanks in advance,
Scot
Thanks in advance,
Scot
well i would say the best 2 are OPM or G-Force
I market G-Force harnesses.
I offer harnesses in latch lock and cam lock
they are SFI aproved
check out my web site
http://www.spectorracing.com
You will like the prices, I sell equipment at wholesale prices.
good luck with your racing
ralph howe
spectorracing motorsports
ralph howe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot »</TD></TR><TR><TD CLASS="quote">I did do a search first... so don't give me any of these...
How about i give you one of these...
instead?
Your search for harness returned the following 42 results.
(Just a few)
https://honda-tech.com/zerothread?id=306311
https://honda-tech.com/zerothread?id=303099
https://honda-tech.com/zerothread?id=295353
https://honda-tech.com/zerothread?id=287568
https://honda-tech.com/zerothread?id=196221
https://honda-tech.com/zerothread?id=127284
https://honda-tech.com/zerothread?id=126561
https://honda-tech.com/zerothread?id=64382
https://honda-tech.com/zerothread?id=43313
instead?Your search for harness returned the following 42 results.
(Just a few)
This is real simple.
SIMPSON has both the Latch type and Camlock. I have the latch version. The online catalog will help you as well. They have an 800 number to call if you are interested. Northeast Safety near Hershey is also a dealer.
The store in Concord, NC is where I generally buy mine, but Summit Racing now stocks them too. The set that I bought (harnesses - PULL Down, belts-PULL Up, and anti-sub strap) came to about $175. This includes the hardware package that permits the belts and and strap to be mounted using 'Eye-bolts', which I think is easier to work with. I too have the REV seat. The harnesses will attach directly to the cross tube on the roll cage behind you. You must specify this mounting method.
If you need pictures of my setup (except anit-submount) I have them. Make sure you follow the Simpson install guide for their belts-very important that it be done right. You will nedd to position the seat where you want it for track/autcross use and then position the belts and strap mounting. Use the huge backup washers that they sell. Other Q's-drop me an e-mail. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
instead?
LOL!
instead?</TD></TR></TABLE>
LOL!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot »</TD></TR><TR><TD CLASS="quote">ahahaha.... i did "racing harness" i think..... i only got 4 results..... o well.... I will give myself the
RJ
's crayons
</TD></TR></TABLE>RJ
's crayons
You should buy my pair of RJS Harnesses (cam lock style).
https://honda-tech.com/zerothread?id=542611
i did just get a quote from OGRACING for a 5 point Sparco black 3" harness (cam, pull down) with mounting hardware(including a small mounting plate for the crotch mount) and shipping for $198.64.
Can anyone beat that and have it to me fairly quickly?
I just bought my Sparco 5 point cam locks from http://www.paragon-products.com. They are a Porsche specialist and great people.
So far nobody has made a good argument against G-force harnesses. From what I understand the sparcos sold in the states are SFI and not FIA rated. The G-force harnesses are SFI rated as well and at the price they are hard to overlook. The camlocks even use the same hardware as the sparcos. Does anyone have a real good reason to not buy G-force?
The G-force stuff uses Sabelt hardware, at least my set did. Sabelt makes the hardware for Sparco.
You just don't get the pimpy Sparco name on it. The webbing may be made stateside though. Check for certs.
Warren
Warren
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">Sabelts are a very good value. Their hardware is top notch too. You can get it through Racer Wholesale.</TD></TR></TABLE>
It looks like RacerWhole sale has moved to the G-Force line of products. At least that is what their website is showing. Maybe they can still offer the Sabelt combo they used to if you call them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">You just don't get the pimpy Sparco name on it. </TD></TR></TABLE>
But the chicks dig it
SPECTORracing - has offered a total package for a 5 point camlock with mounting hardware for $135.
I assume it is http://www.honda-challenge.com approved.
honda-challenge doesnt approve anything.
your hardware has to be approved by the santioning body before you can race.
you need SFI approved harnesses, no more than 5 years old, no tears/rips/grease stains.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">The G-force stuff uses Sabelt hardware, at least my set did. Sabelt makes the hardware for Sparco.
Warren</TD></TR></TABLE>
Not anymore, G Force tooled up and is now making their own hardware (camlocks, etc).
Some of the nicest ones I've seen are from Autopower...at least I liked them. The cam is just a dial, without a little stick thingy coming off it that you can catch with your suit. The cams have a very positive, well-built feel to them. They came from ioportracing.com.
Don't have pictures...sorry, it's not my car.
Did I mention that Summit ships to PA overnight at no added charge via FEDEX Ground. I get my stuff next day. Total price of goods with a $7.95 handling fee added-great packaging. Simpson ships nearly as fast from Texas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote">one word tanaka</TD></TR></TABLE>
You mean takata?
Overpriced JDM crap. No reason to spend that much money when you can get a pair for less than one harness. Hell, even the really really nice schroth harnesses ( http://www.rennsportsystems.com/schroth.html ) are less.
RJ
You mean takata?
RJ
You mean takata?
No, I think he means Tatanka.
You mean takata?
