Headgasket and Headstuds install questions...
Old Jun 29, 2003 | 08:36 PM
TurboJesse
Guest
Posts: n/a
Default Headgasket and Headstuds install questions...
Just wondering if anyone knew a site that had instructions on how to install a headgasket and headstuds on a b series? The headgasket is an inline pro 3mm and ARP studs. Also do i need to spray the gasket with cooper spray? And what should i torque teh studs too? ive heard many different things and im a bit confused...thanks
Old Jun 29, 2003 | 11:25 PM
Foozball26's Avatar
Default Re: Headgasket and Headstuds install questions... (Mpir3)
Instructions for the studs should be with them, however if you used them for a napkin then
Screw them in finger tight
Yes, use copper spray with like 2 coats 30 secs apart letting the spray get tacky.
Slap head on
Put moly lube on the upper threads
Torque to spec
Spec was 65 lbs on my B18B most torque to 70 ft lbs for giggles as did I
If you use regular motor oil torque them to 80-85 ft lbs, use the moly lube though its what the studs are designed with
If you ever need to double check something important for sure like this, call ARP they will tell you torque specs, install etc.
Believe it or not there is some wrong info on here
Old Jun 30, 2003 | 01:14 AM
1titesol's Avatar
Default Re: Headgasket and Headstuds install questions... (Foozball26)
If I'm not mistaken the arp's should be 10 lbs less then factory specs. The arp are not supposed to stretch like the honda factory head bolts. I would also call arp, just for the right specifications.
slo_b18
Jan 30, 2008 08:47 AM
ivt-t
Feb 8, 2007 09:15 PM
SOHC_MShue
Jun 6, 2004 12:54 PM
UncleBen'sRacing
Apr 25, 2004 02:50 PM
Boost2NA
Jul 28, 2003 05:08 PM
