poor man r setup times
this will be the setup:
b16a head- ported
gsr shortblock
jdm 4-1 w/2.5 collector
full 2.25 exhaust header back. no cat.
CAI
ls tranny
lightened stock flywheel 13lbs
i was thinking this would put down about 180ish to the wheels. and put me through at about 14.5
. high 13 when i get the vtec series cable tranny with good clutch.
b16a head- ported
gsr shortblock
CAI
ls tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuit_ _ _ »</TD></TR><TR><TD CLASS="quote">why are you using an ls tranny?</TD></TR></TABLE>
do you want to give me 750 for tranny and clutch set? thats why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">
do you want to give me 750 for tranny and clutch set? thats why.</TD></TR></TABLE>well i was just thinking that if your gonna be spending that much money on motor mods ...you might as well get a tranny...sorry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuit_ _ _ »</TD></TR><TR><TD CLASS="quote">well i was just thinking that if your gonna be spending that much money on motor mods ...you might as well get a tranny...sorry</TD></TR></TABLE>
check sig.
i already have everything else.
check sig.
the usdm gs-r ysi is a cable tranny but will accept 92- hydraulic gear sets. this would be the best tranny for my setup.
jdm xsi with limited slip shorter geared
jdm si-r with no limited slip with taller gearing than xsi
ls tranny is going to slow you down significantly 1/4 wise
in my previous stock b16 crx i was hitting low 14s, when my b16 tranny took a dive i switched over to an ls tranny and the best i could hit was 14.9 and the rest were in the 15s
throw some itr or ctr pistons in there
180's is possible. I put down 182hp and 134 torque with 11.1:1 CR and GSR cams. So, I don't see why you couldn't do it either. Except if I were you I'd convert to OBD1, the non-OBD system is a big choker for any motor. 13's is possible as well, I ran a 13.7 @99.6 with a 2300lb 99 Si on drag radials.
spoon23_JDizM AkA SpOoN20
Dec 4, 2004 04:22 AM
