del sol climate control unit....help me take it out!
ok so far, i have taken that pain in the *** screw that goes strait up from under where the radio sits. it doesnt slide out or anyhting (yet) i can feel different plugs back there but they are hard to get to. what do i need to do next for this to be a successful extraction?
i don't know how similar the climate control is to an EK civic, but i recently did it and this what i needed to disconnect:
after any screws: (there was more than 1)
1. two plugs going into the back of the unit. I just had to reach my hand up under the dash and look for the tab on the plug to push down, then slide the plug out
2. the temp adjustment cable thing. this is the cable that connects to the slider that adjusts the temp. I tried to disconnect this from the back of the unit and it wouldn't work. I ended up having to follow the cable back to the firewall (up to the firewall i mean) and disconnect it from where it was connected to something up there. it was like the wire made a circle on the end of the wire. this circle looped over this metal lever. i just had to slide it off of the lever.
After those threet things were disconnected it came right out.
Hope this helps
Hope this helps
