balance bottom end after lightened flywheel install?
Old Jun 28, 2003 | 03:50 PM
euclid's Avatar
Default balance bottom end after lightened flywheel install?
i am installing a findaza flywheel and action clutch, will it cause problems in the balance of the motor, does honda balance the bottom end with the flywheel installed at the factory? thanks
Old Jun 28, 2003 | 06:51 PM
vtec.dc2's Avatar
Default Re: balance bottom end after lightened flywheel install? (euclid)
first i heard of the need to re-balance the motor for removal of transimssion...
misuse or improper installation may cause problems.. for clutch/transmission part(s) before anything..
Old Jun 28, 2003 | 06:58 PM
SurferX's Avatar
No, the flywheel does not act as a harmonic balancer.
Old Jun 28, 2003 | 10:10 PM
euclid's Avatar
Default Re: balance bottom end after lightened flywheel install? (SurferX)
i realize it doesnt work as a harmonic balancer but if honda balanced the crank at the factory with the flywheel connected, then switching the flywheel to a different weight will throw off the balance of the block internals. so does anyone know if they do have the flywheel connected when the motor is balanced by honda?
Old Jun 28, 2003 | 10:38 PM
Evs-One's Avatar
Solbros Owns Me
the flywheel SHOULD be perfectly symetrical and not cause any "balancing" problems. Bolt it on and go
Old Jun 29, 2003 | 08:00 AM
euclid's Avatar
Default Re: balance bottom end after lightened flywheel install? (Emerika)
up
Old Jun 29, 2003 | 09:28 AM
gamby's Avatar
I've done plenty of hard racing (drag, auto-x, HPDE) miles as well as daily driver miles on my Exedy 9.1 lb flywheel (on a B16A) and there isn't even a question balance issues.
It's a great mod.
lilo_goki
24
Mar 18, 2008 06:37 PM
immalooser
Oct 18, 2005 08:08 PM
One Bad GeeSeeR
Dec 26, 2003 06:26 AM
pentaq
Apr 29, 2003 04:36 AM
JM Performance
Oct 2, 2001 11:34 PM
