I just got my T3 turbo....?'s regarding rebuild and shaft wobble
Old Jun 28, 2003 | 01:28 PM
racinskittle's Avatar
Default I just got my T3 turbo....?'s regarding rebuild and shaft wobble
Hey I got my T3 turbo today and I just found out that it has shaft wobble. IT spins well and there is no shaft play in it, but it does wobble.
When i pull it toward the compressor housing and spin it, it moves far enough so you can hear it scrape LIGHTLY against the compressor housing.
My questions are:
Is it time for a rebuild on it? Or will it be ok for a while?
Also, are all T3 rebuild kits the same? This is T3 turbo off a mustang SVO .63/.60A/R.
Thanks
Dan
Old Jun 28, 2003 | 01:54 PM
MayhemSi's Avatar
Default Re: I just got my T3 turbo....?'s regarding rebuild and shaft wobble (racinskittle)
Yes it definitely needs a rebuild if its lightly scraping. You don't want little metal shavings thrown into your motor. As far as the rebuild kits go, I'm not sure how many different kits there are so someone else on here will have to answer. I just call up a local turbo company and tell them the specs on my turbo and they get the right kit for it. Its not a bad idea to get it professionally done with the balancing tools they have to make sure that the scraping hasn't unbalanced the turbo.
Old Jun 28, 2003 | 02:03 PM
GraphiteAccord's Avatar
talk to Paul_vang, he'll point ya int he right direction
Old Jun 28, 2003 | 03:01 PM
Default Re: I just got my T3 turbo....?'s regarding rebuild and shaft wobble (MayhemSi)
sweet thanks. I appreciate the reply. Ill def. rebuild it then. I was gonna have ForcedPerformance do the balancing for like $30 and the rebuild it myself.
Thanks again
Dan
Old Jun 28, 2003 | 03:19 PM
RuthlessEF-9's Avatar
ahh Mr. Vang he's the man help you out real good great customer service but very hard to get a hold of since his cell phones gone
BoostedD15B7
Feb 16, 2003 11:25 AM
Full-Race Geoff
Aug 31, 2002 08:19 AM
AlphaKennyWun
Feb 16, 2002 09:52 AM
