My compression #`s on JDM GSR w/ ITR slugs: your input please...
Old Jun 28, 2003 | 01:08 PM
NiiS's Avatar
Default My compression #`s on JDM GSR w/ ITR slugs: your input please...
I don`t know whether to smile or cry:
<FONT COLOR="red">
1: 205
2: 210
3: 210
4: 220
</FONT>
This is good, normal, or poor?
TIA!
Old Jun 28, 2003 | 01:39 PM
eg_nezay's Avatar
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (sinister)
Good #s
I would check it again, I bet the #1 goes up.
Also, you dont want them to have more than %10 difference from one another.
Old Jun 28, 2003 | 07:03 PM
Lord Helmet's Avatar
sounds about right, maybe add a little oil to cylinder #1.
Old Jun 28, 2003 | 10:50 PM
IN VTEC's Avatar
Rebuilt motor? New rings?
What brand of compression tester gauge?
Old Jun 28, 2003 | 10:52 PM
NiiS's Avatar
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">sounds about right, maybe add a little oil to cylinder #1.</TD></TR></TABLE>
Funny you should mention that. My question is won`t that just mask the low compresion in that cylinder though? I read that it is a sign of bad rings...So adding oil will only help that seal temporarly, won`t it?
Old Jun 28, 2003 | 10:57 PM
NiiS's Avatar
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (IN VTEC)
The rings and pistons are relatively new, maybe 5k on them, all harsh conditions though. I use regular 5W30 oil, I wanna say the brand is Snap-on, I don`t know tho...
Old Jun 29, 2003 | 07:36 AM
IN VTEC's Avatar
The absolute values are probably just fine. The Mac Tools digital gauge I used read about 52psi lower than the Sears gauge I had (260psi vs. 208psi) on back-to-back readings.
Redo the test and standardize the number of cranks to 8. That will help to standardize the comparison b/w the cylinders.
Old Jun 29, 2003 | 10:41 AM
Ivan's Avatar
senior gold member
I thought you're suppose to crank the motor till it doesn't go any higher?
Old Jun 29, 2003 | 10:44 AM
IN VTEC's Avatar
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (Ivan)
That's much too subjective for cylinder-to-cylinder comparisons. The gauge will still go up little by little.
Old Jun 29, 2003 | 12:26 PM
poison's Avatar
those are pretty good numbers.
for cyl #1, could be the rings or ringlands, also make sure the head bolts and all that is torqued properly.
Old Jun 29, 2003 | 12:29 PM
Ivan's Avatar
senior gold member
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">those are pretty good numbers.
for cyl #1, could be the rings or ringlands, also make sure the head bolts and all that is torqued properly.</TD></TR></TABLE>but its only a small difference. I would be scared if it was off a little more then that. The difference here could be cause by something else. gauge, not the same amount of cranks, or something else?
Old Jun 29, 2003 | 12:54 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister &raquo;</TD></TR><TR><TD CLASS="quote">I don`t know whether to smile or cry:
<FONT COLOR="red">
1: 205
2: 210
3: 210
4: 220
</FONT>
TIA!</TD></TR></TABLE>
seems aite, what was your method of compression testing?
It all seems to depend on what compression tester you use.
The sears one I have, it says that my friends 10.6 JDM h22 motor is 270...
it says that my 9.97:1 b20vtec is 215-220
take that for what its worth.
Old Jun 29, 2003 | 03:37 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (irev210)
looks fine.
Old Jun 29, 2003 | 04:16 PM
speedymon's Avatar
Default Re: My compression #`s on JDM GSR w/ ITR slugs: your input please... (vtecvoodoo)
My 10.6:1 compression motor read 280ish. Autozone tester. Hot motor, open throttle.
turbo-crx
Oct 10, 2007 09:29 AM
nekoabandoned
Jul 24, 2006 03:39 PM
iBrandon
Apr 19, 2006 03:51 PM
TypeR0186
Jul 21, 2004 07:40 PM
servion
Jun 12, 2003 09:18 AM
