Jrsc removed, help me ID some parts
Old Jun 28, 2003 | 12:30 PM
Batoutahell's Avatar
Default Jrsc removed, help me ID some parts
I'm trying to identify the PCV valve. I found a lot of oil in my jrsc and manifold, so I would like to see if it is blowing past the PCV. Can someone please circle the PCV in this pic? BTW, what is the black box to the right of the oil filter?
Old Jun 28, 2003 | 12:42 PM
GreddySi99's Avatar
Default Re: Jrsc removed, help me ID some parts (Batoutahell)
the PCV valve I think is the red piece in the picture. although I thought it was located in the manifold stock
Old Jun 28, 2003 | 01:50 PM
sporkcrx's Avatar
Default Re: Jrsc removed, help me ID some parts (intercooledJRSC)
It's usually ON the intake manifold...not sure what happens to it with the charger though. The black box is the stock "catch can"
Old Jun 28, 2003 | 01:57 PM
Default Re: Jrsc removed, help me ID some parts (sporkcrx)
That was my guess, I just needed a second opinion.
Old Jun 30, 2003 | 11:47 AM
roadrunner's Avatar
As someone already pointed out, the PCV valve is the red plastic piece attached to the hose. That is stock location for the vtec engines, whereas the B18B non-vtec has the PCV on the valve cover. The black box is the oil vapor separator (catch can).
Old Jun 30, 2003 | 01:26 PM
Default Re: (roadrunner)
I will be adding the Endyn catch can to my car as soon as it arrives in the mail. It should cure my "blow-by" issues, and cut down on my massive oil consumption. From the installation directions, it looks like it is mounted in-line ahead of the stock separator box. I'm wondering, while I'm digging around that area, whether I should clean out or change the stock separator box. Is there any kind of filter element in there that can be cleaned out?
bdjimz
Dec 25, 2008 08:31 AM
drew_kousk
Jul 26, 2008 09:21 AM
B18Flip
Sep 21, 2002 08:26 AM
pg_thao
May 21, 2002 03:52 PM
