Running lean after driving on freeway?
Old Jun 28, 2003 | 11:44 AM
VtecDA9's Avatar
Default Running lean after driving on freeway?
I noticed just recently that my car starts running whack when I drive it for like 20-30 min. I check the plugs after and they are on the real line side. Then when I check the plugs after 5 min of idle in the morning, they are really rich, but that's because I set my timing to stock and fuel pressure to 45psi at idle. Could this be my fuel pump dying or the fuel filter which I wouldn't understand cuz I had it changed a couple years ago??? i'm running roughly 11.6-.9 c/r with stock LS fuel pump on ls/vtec. I've had the swap for 1600 miles now... you think the pump is giving up? I don't rev past 5000 any more to be safe. Oh and especially whne I'm low on fuel...
Old Jun 28, 2003 | 11:53 AM
eg6ajk's Avatar
Default Re: Running lean after driving on freeway? (VtecDA9)
when the motor is cold and its idling its always going to be lean. what type of a ECU/Program are you running, if its a stock PW0/PR3 or other B16A stock ecu then yes its going to be lean while cruising.
Old Jun 28, 2003 | 11:58 AM
VtecDA9's Avatar
Default Re: Running lean after driving on freeway? (eg6ajk)
No it runs rich at idle, can smell the gas.... i'm running a sk2 chipped p28
JDM_ego2033
Engine Management and Tuning
May 1, 2018 07:53 AM
dragonjay006
Nov 4, 2014 08:16 PM
97grnrs
Nov 6, 2006 06:42 PM
mikeunreal2
29
Mar 22, 2006 06:26 PM
redlseg
12
Aug 12, 2005 04:44 AM
