Constant Valve Adjustments
Old Jun 28, 2003 | 11:29 AM
Chuji's Avatar
Default Constant Valve Adjustments
Everytime I do a valve adjustment about 2 weeks later my valvetrain is very noisy and alot of the valves are outta spec again. The head is a 00' b16 head so its pretty new. The only thing I can think of is the valve springs are worn out. Any idea what is causing this problem?
Old Jun 28, 2003 | 11:45 AM
eg6ajk's Avatar
Default Re: Constant Valve Adjustments (Chuji)
check out the torque on the valve train (cam caps and so on)
also look at the rocker and a cam for unusual wear.
ie. look at the this example( thanks to Jeff of HybridAutomotive
Old Jun 28, 2003 | 11:47 AM
kaj's Avatar
kaj
i had mine adjusted. within a week or two they were noisy again also. i have 133k on a b18c.
Old Jun 28, 2003 | 12:21 PM
Fkned2003's Avatar
just a guess but did u make sure the locking nut on the lash adj. screw is tight ? maybe try a small amount of blue locktite on the nut ,if it is really backing off.
Old Jun 28, 2003 | 12:26 PM
MikeSarr_GSR's Avatar
Default Re: (Fkned2003)
if you drive high rpms alot on worn out LMAs this can happen too. my old GSR had CTR cams in it and I drove it high RPM all the time valves would come outta spec due to the abuse. I still have GSR cams on this head with ITR springs and LMAs I drive her hard all the time and check the valves every oil change. They rarely ever move from .007",.008". Do you run adjustable cam gears?
Old Jun 28, 2003 | 12:34 PM
kaj's Avatar
kaj
Default Re: (MikeSarr_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">if you drive high rpms alot on worn out LMAs this can happen too. my old GSR had CTR cams in it and I drove it high RPM all the time valves would come outta spec due to the abuse. I still have GSR cams on this head with ITR springs and LMAs I drive her hard all the time and check the valves every oil change. They rarely ever move from .007",.008". Do you run adjustable cam gears?</TD></TR></TABLE>
i run turbo. NO adjustable cam gears!!
Old Jun 28, 2003 | 08:00 PM
2chron4u's Avatar
Default Re: (kaj)
the first time I did my valve adjustment it started ticking after about a week. I redid it, wasn;t good enough, dit it again, wasn't good enough, 3rd time was th charm and it's been excellent for about 7 months now.
Old Jun 28, 2003 | 10:57 PM
Default Re: (2chron4u)
yea, not exactly the easiest thing to do when you first start.
now I can pretty much do it blindfolded, granted I had the right
feeler gague...
rotascircuit
Dec 16, 2009 02:58 PM
remoer
Jan 21, 2009 12:09 PM
NA JDM GSR
Oct 17, 2006 10:35 PM
600_Double_R
Jun 8, 2006 06:47 AM
IntegraXSi
Nov 13, 2005 05:18 PM
