does the valves close when cams are taken off?
Old Jun 28, 2003 | 12:28 AM
216.226.142.95:27016's Avatar
Default does the valves close when cams are taken off?
when cams are taken off the head does the valves close since there is no pressure on the rocker arms?
n00b question, i cant visualize
Old Jun 28, 2003 | 01:19 AM
sgT's Avatar
sgT
Default Re: does the valves close when cams are taken off? (216.226.142.95:27016)
yes
Old Jun 28, 2003 | 01:41 AM
SIRX's Avatar
Default Re: does the valves close when cams are taken off? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE> you took the easy answer . Yes when the cam is outta the head there is nothing to keep the valves open anymore. the cam controls the duration and lift of the valves. It other words the cam lobes are designed to open the valves and keep them open for a certain amount of time. This is why you can buy after market cams that will open faster stay open longer and close quicker. The allow more fuel and air into the combustion chamber. With more air and fuel to burn it creates more power. So when the cam is out of the head the valves stay closed because the lobes of the cam are not there to keep them open. Probably a little more than you needed but It's the only way to learn
SHG_Claudio
Nov 19, 2007 10:10 AM
r1de4life
Sep 12, 2007 11:06 AM
soulpwr
22
Jun 13, 2007 07:44 AM
matata55
Dec 23, 2004 09:54 PM
daNk9
Apr 5, 2004 03:54 PM
