DA B18A head
Old Apr 3, 2004 | 06:50 PM
daNk9's Avatar
Default DA B18A head
I wanted to rebuild my head on my DA. What parts will i need to bring a little more power on the top end? thanks
Old Apr 3, 2004 | 09:03 PM
zilverz's Avatar
Default Re: DA B18A head (daNk9)
get it ported polished... oversized valves .. valve train for aggressive cams ... and some aggressive cams + cam gears to tune them
Old Apr 3, 2004 | 09:51 PM
psychotic_z's Avatar
Default Re: DA B18A head (zilverz)
Get head work done, then get a high performance valvetrain and install good cams... Crower 42403's and 42404's made really, really good power if you combine them with high compression pistons. Your powerband'll shift to the right and you'll make a good amount of power, and you'll probably monkey rape most GSR's up and down.
Old Apr 4, 2004 | 12:03 AM
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zilverz &raquo;</TD></TR><TR><TD CLASS="quote">get it ported polished... oversized valves .. valve train for aggressive cams ... and some aggressive cams + cam gears to tune them </TD></TR></TABLE>
I was going to do the same with the oversized valves; but I looked into it and it seems to much more of a hassle. Just a thought. Id just keep the stock valve size; and port that bitch hehe
I walk on GSRS now with just bolt ons
Old Apr 4, 2004 | 12:46 AM
Ditdogs's Avatar
PP, 3 angel valve job, and a *******
Old Apr 5, 2004 | 03:45 PM
daNk9's Avatar
Default Re: DA B18A head (Ditdogs)
how much will all that come to ?
Old Apr 5, 2004 | 03:54 PM
FR-MOB: ThE bEe GuY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ditdogs &raquo;</TD></TR><TR><TD CLASS="quote">PP, 3 angel valve job, and a *******</TD></TR></TABLE>
hahahah
Anyways, http://www.g2ic.com might help you a lot more. Its a board specifically for DA's. A lot of people over there use the Crower 403's and get pretty good results, im planning on getting those for my DA when i get some cash in. The 404's i hear are hard to get to idle, and theyre supposed to be for race only (that never kept anyone from using them on the street though )
J-Spot
22
Sep 27, 2007 10:15 AM
r1de4life
Sep 12, 2007 11:06 AM
urtz
Jun 18, 2007 01:30 PM
krystianitr
Sep 25, 2005 08:05 AM
matata55
Dec 23, 2004 09:54 PM
