Guys with grinds in your tranny...
Old Jun 27, 2003 | 10:45 PM
nY's FiNeSt's Avatar
Default Guys with grinds in your tranny...
Hey i had a quick question for you people with a grind in your tranny. If you shift hard into that gear with the grind, do you sometimes mis-shift and grind it worse?
I tried shifting hard into it and i mis-shifted, i felt like an idiot. And if you guys say i'm an idiot for shifting hard into that gear in the first place, it's because i'm getting my new tranny this weekend so i wanted to check a few things out.
Let me know if you've had the same problem
Old Jun 27, 2003 | 11:03 PM
DCStreetHtch's Avatar
Default Re: Guys with grinds in your tranny... (nY's FiNeSt)
my third gear grinds a bit when shifting hard (fast).
of course the faster you shift the worse it will be, the synchros are fucked so the faster you shift the worse it will be.
its all about finesse... i plan on getting a short shifter soon and im curious to see if it makes a difference in the grind. I had a gsr shifter welded to my d-series linkage back in the day and it grinded just because of poor alignment... im curious to see if i have the same problem now and a different shifter will adjust it?!?!
we'll see i guess.
-Bryan-
Old Jun 27, 2003 | 11:10 PM
Default Re: Guys with grinds in your tranny... (EGStreetHtch)
i know it'll grind if i shift fast (hard), i'm talking about mis-shifts. Because i usually don't miss a gear and tonight i missed my 3rd and it grinded even more like a ****, it gave me the chills
so i guess my question is, do you have a higher possibility of mis-shifting if you have a grind in your tranny?
Old Jun 27, 2003 | 11:16 PM
Evs-One's Avatar
Solbros Owns Me
to answer your last question, yes.
If you're used to driving a car with a smooth tranny, then the chance of mis shifting will increase because it's usually harder to get in gear. When my 3rd synchro was out, it was a pain shifting fast and smooth into 3rd, and mis shifted more than needed
Old Jun 27, 2003 | 11:19 PM
Default Re: Guys with grinds in your tranny... (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">to answer your last question, yes.
If you're used to driving a car with a smooth tranny, then the chance of mis shifting will increase because it's usually harder to get in gear. When my 3rd synchro was out, it was a pain shifting fast and smooth into 3rd, and mis shifted more than needed </TD></TR></TABLE>
ahh, thank you very much! Tonight i was so embarassed when i mis shifted, i felt like a noob
Old Jun 30, 2003 | 11:43 PM
JDMTRSPORTS's Avatar
man everytime that i put it in 3rd gear it grinds some people say its my sincros but if it is how much would it be to fix it
Old Jun 30, 2003 | 11:56 PM
locass316's Avatar
IMO its not worth fixing. just get another tranny and sell the broken synchro one.
Old Jul 1, 2003 | 10:18 AM
Default Re: (locass316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locass316 &raquo;</TD></TR><TR><TD CLASS="quote">IMO its not worth fixing. just get another tranny and sell the broken synchro one.</TD></TR></TABLE>
Old Jul 1, 2003 | 10:21 AM
BauleyCivic's Avatar
Risky Business
Default Re: (nY's FiNeSt)
yeah i grind 3rd gear a lot...but only when i am shifting hard, but i have never mis-shifted
Old Jul 1, 2003 | 11:10 AM
eg686's Avatar
Default Re: (BauleyCivic)
how much could u sell the tranny that is grinding?
my tranny is grinding badly, do i need to replace it soon?
does getting a short shifter reduce my chances of grinding? skunk 2 a good short shifter?
Old Jul 1, 2003 | 11:19 AM
976's Avatar
976
New User
Default Re: (nocaryet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocaryet &raquo;</TD></TR><TR><TD CLASS="quote">how much could u sell the tranny that is grinding?
does getting a short shifter reduce my chances of grinding? skunk 2 a good short shifter? </TD></TR></TABLE>
A short shifter will increase the chance of wrecking synrcos. It will not prevent grinding of a gear either way. However, if you shift slow, and press clutch fast, a shoft shifter might be a good idea.
Skunk 2 makes decent parts. I've heard bad things about almost every short shifter, Honda designs the shifting mechism for a reason.
Has anyone had success with GM Synrcomesh Fluid?
Old Jul 1, 2003 | 11:23 AM
im also curious on how much i could sell my 94 ls tranny w/grind in 3rd
hatchback's Avatar
i grind 2nd gear like a ****, im going for a tranny rebuild.
Old Jul 1, 2003 | 11:52 AM
Default Re: Guys with grinds in your tranny... (hatchback)
how much would it be to rebuild ur tranny
Hephro.T
Sep 27, 2016 11:22 PM
davidluko
Dec 17, 2006 10:51 AM
insidious408
May 26, 2006 11:48 AM
743power
17
Oct 25, 2003 06:04 AM
743 Stunna
Oct 19, 2003 09:58 AM
