need help fast
Old Jun 27, 2003 | 10:40 PM
thehondaguru's Avatar
Default need help fast
I have been having problems lately with my car hesitating like crazy so I changed all the tune up stuff and no difference. It has almost100,000 miles on it so I thought maybe the valve needed adjustment. So I adjusted the valves and now it has no power at all. No check engine light , at idle its fine and ounce I get up to speed the car runs great. When unbder any kind of aceleration its crap. I mean reallybad. I know I adjusted the valves right but I am thinking my timing was messed uo in the first place and know adjusting the valves made it worse. What u guys think. I really need help and suppod]sed to go to the track on sunday
Old Jun 27, 2003 | 11:16 PM
MAX HARDCORE's Avatar
Default Re: need help fast (95 lude)
may be you bent a valve? or check your map sensor??
what is it doing exactally. or check you sensor in and sensor out on your vafc
had that happen to me before?
Old Jun 27, 2003 | 11:34 PM
Default Re: need help fast (MAX HARDCORE)
I'll try that but I think my timing might be messed up. causing the hesitation in the first place and me readjusting the valves making it worse. CouldI be right or wrong I dont know
Old Jun 27, 2003 | 11:41 PM
hard to say bud? i mean if your timming is off your going to lack power on the low end depending if it's advanced or retarded. if you did your timing belt and you were not sure if you were TDC and then adjusted your valves your on your own!
but again if it were a map sensor your prob going to throw a code,
NO SERVICE LIGHTS RIGHT? a shitty o2 sensor will make you run like ****. i would jump out you ecu for a code. may be your getting soft codes that may not pop up?
Old Jun 28, 2003 | 12:09 AM
Maybe I dont know....I am gonna havea mechanic take a look at it tommorrow. Hop[fully we canfix it thanx for your help
loc_yaj
Apr 12, 2008 06:40 PM
dwittlturbo
Jun 19, 2005 05:04 PM
thehondaguru
Jun 28, 2003 12:33 AM
mracura
May 27, 2002 05:33 PM
turbotec
Feb 26, 2002 03:34 PM
